Author Topic: Spark Plug - oil spot around plug  (Read 3146 times)
Sept
« on: May 14, 2016, 14:33:33 »
I noticed today a "wet spot" of oil around the No. 4 spark plug on our car..1971 280 SL.  This would indicate it's blowing a bit of oil around the plug when running..it isn't very much but it is wet to the touch.  Thoughts on what's causing this?
Re: Spark Plug - oil spot around plug
« Reply #1 on: May 14, 2016, 15:30:42 »
The oil could be caused by the ball stud base in the head just above the spark plug. You can use a small mirror to check it out.
http://www.sl113.org/forums/index.php?topic=16157.msg111692#msg111692
Sept
« Reply #2 on: May 14, 2016, 19:16:16 »
Thanks..
