Author Topic: Locked sterile wheel and ignition stuck on #3  (Read 3461 times)
cruising
« on: May 09, 2016, 20:09:54 »
Please help me...I was so excited after I rebuilt my alternator because I was sure this was going to solve my engine problems. I stick my key in the ignition and it locks into position 3 and then the steering wheel locks. I have used graphite, wD40, wiggled, jerked and cursed. What do I do now??  :'( Thanks in advance!!
kampala
  • USA, CA, Hermosa Beach
Re: Locked sterile wheel and ignition stuck on #3
« Reply #1 on: May 10, 2016, 06:58:29 »
Typically when the wheel locks, you can unlock by cranking the steering wheel and trying to turn the key while at the same time.  The steering wheel may only move a touch, just enough to take the tension off the lock, but that's usually enough to unlock.
See also the link below, there are probably more.
http://www.sl113.org/forums/index.php?topic=13430.msg91329#msg91329
250sl - later - manual
280sl - 1971 - Auto - LSD
Mechudo62
  • Mexico, Distrito Federal, Mexico City
« Reply #2 on: May 11, 2016, 02:00:56 »
I agree, the condition described happened to me but was able to free the steering mechanism by gently wiggling the steering wheel to relieve pressure from the ignition lock.
Greetings from sunny Mexico!
Fernando Mangino
