Author Topic: Two-way valve  (Read 4381 times)
CJHenderson
  • USA, AR, Benton
Two-way valve
« on: April 30, 2016, 19:25:28 »
Attached is a photo of a two-way valve on right side of photo. It has two vacuum hoses and a electrical connector. both vacuum hoses have been cut and have no idea where they go to. Who ever worked on this car felt that it would run better with the hoses cut but I would like to reconnect it when I start the rebuild. Thanks for any and all help'
1970 280SL/8 W113 101624 miles.
1950 MG-TD
2021 Harley Davidson CVO Trike
Pinder
  • USA, NJ, Edison
Re: Two-way valve
« Reply #1 on: April 30, 2016, 19:40:47 »
I have have that on my 1970280SL and its part of the emissions control and it adjusts the timing.  One end goes to the intake manifold port. the other end goes to the vacuum retard on distributor.   Someone probably bypassed it just like I did.
2015 BMW 320i xdrive
2021 Mercedes GLS450 Silver
Pinder
  • USA, NJ, Edison
Re: Two-way valve
« Reply #2 on: April 30, 2016, 19:44:14 »
If they bypassed it they must have drilled a new port of the throttle body lower down. If you use this two way valve you have to hook it up to the port thats on the upper side of the intake manifold.  The difference is that if you use this value it requires vacuum all the time.  If its been bypassed then the vacuum line from distributor to intake manifold should be connected to the port on the lower / bottom of the intake manifold throttle body.
CJHenderson
  • USA, AR, Benton
Re: Two-way valve
« Reply #3 on: April 30, 2016, 20:27:37 »
I see the vacuum line from distributor to throttle body. Then really don't need to put it back on the car then.
1950 MG-TD
Pinder
  • USA, NJ, Edison
Re: Two-way valve
« Reply #4 on: May 01, 2016, 12:58:28 »
yes. Personally i would leave it disconnected as long as prior person has vaccum line hooked up to lower part of throttle.
Re: Two-way valve
« Reply #5 on: May 01, 2016, 18:14:57 »
The vacuum line from the throttle body always goes to the center port on the switch over valve. Even new MB cars are set up this way. I would not play around with the throttle body trying to make something happen when it was never designed to work that way.
Pinder
  • USA, NJ, Edison
Re: Two-way valve
« Reply #6 on: May 01, 2016, 20:10:08 »
Yes the correct thing would be to put it back to original assuming all the temp sensors and electronics still work.
