Author Topic: Unknown Relay R/H Engine compartment  (Read 4849 times)
CJHenderson
  • USA, AR, Benton
« on: April 28, 2016, 18:37:24 »
Have a relay on the right side of engine compartment just aft of the shock cover. Looked in Chilton manual cannot locate it.
1970 280SL/8 W113 101624 miles.
1950 MG-TD
2021 Harley Davidson CVO Trike
Re: Unknown Relay R/H Engine compartment
« Reply #1 on: April 28, 2016, 18:55:02 »
Voltage regulator
CJHenderson
  • USA, AR, Benton
« Reply #2 on: April 28, 2016, 19:03:00 »
Great thanks
1950 MG-TD
« Reply #3 on: April 28, 2016, 23:47:48 »
I found when I checked the voltage with the alternator turning, it would read 12 volts. It should read about 13.8 volts. So I opened it up and turned the little screw until it read 13.8 volts. I wonder why my battery is now happier.
awolff280sl
  • USA, FL, Sarasota
« Reply #4 on: May 01, 2016, 11:17:45 »
I was not aware that the output voltage is adjustable.
Where is this little screw located?
Andy   Sarasota, FL
'69 280SL 4speed
'06 Mitsubishi Evo
Tyler S
  • USA, CA, Encinitas
« Reply #5 on: May 01, 2016, 15:04:46 »
Andy, If you remove the top cover you will see the adjustment. Cleaning the contacts often helps as well. Only the Original regulators have this adjustment. The replacement ones are not adjustable.
