Author Topic: Ball stud sealer? What to use?  (Read 4342 times)
erickmarciano
  • Canada, Quebec, montreal
« on: March 31, 2016, 16:27:58 »
Hi guys
Have to reinstall all the ball studs on the head? What is the bedt choise sealer
Red locktite?
1994 E500 W124
1971 280sl
1989 Porsche 930 coupe
1988 e30 m3
2001 ducati mh900
2006 ps1000
1962 Vespa GS160
Re: Ball stud sealer? What to use?
« Reply #1 on: March 31, 2016, 18:20:49 »
Something like this is another option http://www.permatex.com/products-2/product-categories/thread-compounds/thread-sealants/permatex-thread-sealant-with-ptfe-detail
The temperature rating is key as these are near exhaust gases. I use this for many coolant applications with great results and is non-hardening. Will also provide a barrier for corrosion between the steel and aluminum.
« Reply #2 on: March 31, 2016, 20:45:05 »
Don't use anything that would keep you from being able to remove the ball studs. I also use Permatex thread sealant which will work just fine for this application.
« Reply #3 on: April 01, 2016, 04:32:42 »
Yes, I agree on the Permatex!
Raymond
  • USA, FL, Jacksonville
    • GemstoneMediaInc.com
« Reply #4 on: April 04, 2016, 14:52:13 »
Locktite would be a bad idea.  Someone did that or something like it, to the ball stud over the 6 spark plug before I got the car and the threads in the aluminum head were destroyed when it was removed.  I had to drill it out and put in a thread insert.  Definitely use the permatex thread sealer.  Otherwise it WILL leak.
erickmarciano
« Reply #5 on: April 05, 2016, 16:53:48 »
omg these were so hard to put back on  , put them in dry ice or freezer before installing
thanks
1994 E500 W124
1971 280sl
1988 e30 m3
2001 ducati mh900
2006 ps1000
1962 Vespa GS160
