Author Topic: did I disturb the injection pump timing while removing tach drive?  (Read 3074 times)
erickmarciano
  • Canada, Quebec, montreal
Hi guys could I have disturbed the injection pump timing while removing the tach drive?
It was really hard to remove and as I was trying the chain moved < head is off> .
by the chain moving could that disturb Injection timing? I am able to move the distributor by turning the gear one way the other way It does not move , I suspect it moves with the crank
« Last Edit: March 29, 2016, 02:32:16 by erickmarciano »
1994 E500 W124
1971 280sl
1989 Porsche 930 coupe
1988 e30 m3
2001 ducati mh900
2006 ps1000
1962 Vespa GS160
Should not have moved.
Tyler S
  • USA, CA, Encinitas
The only way the intermediate shaft to crankshaft relation would have moved is if the chain jumped a tooth on the intermediate shaft. This is not possible unless you removed the bolt/pin on the engine block. This bolt/pin is on the front, and side of the block at the 3 o-clock position in relation to the distributer drive housing. It also secures the power steering pump bracket.  It keeps the chain from leaving the intermediate shaft sprocket.
