Author Topic: Brake Shoe Separation. ...I'm glad we have this site!  (Read 4615 times)
vande17941
  • USA, CA, Irvine
« on: March 06, 2016, 00:44:57 »
After driving the 230sl on a road trip for about 150mi at autobahn speeds and then on some nice mountain twisties......got about 2 miles from home  and heard a huge "clunk" as if the drive train was about to fall out of the car.
I got on this site, searched for "clunk" and then took off the brake drums...20min and the problem was found. How great is this site and the people on it? Great.
Now....who has the hot recommendation on where to get some new shoes. Preferably someplace where I could get a new/rebuilt set and send these back as cores. I'm in California...though, I doubt that matters since everything is shipped nowadays.
Any recommendations would be great. Thanks!
'66 USA (1967 model Year) 230sl, 4-speed Manual, Driven Like a Real Car! Set up with KYB Stiffer Shocks, and Motor Mounts w Urethane Inserts Underneath, 3-point Belts, Headrests Installed 🚗
1986 560sl Cabernet & Palomino (not recommended)
2001 SLK320 Sport AMG Silver & Black
jameshoward
Re: Brake Shoe Separation. ...I'm glad we have this site!
« Reply #1 on: March 06, 2016, 12:03:49 »
Call some truck (as in 18 wheeler type truck) service depots. Trucks - at least in Europe - re-line drum brakes all the time and it's likely to be cheaper than sending to some 'classic car specialist' who will probably send them to the same place as the truck guys anyway!
James Howard
1966 LHD 230SL
merrill
« Reply #2 on: March 06, 2016, 13:38:50 »
Hi
Check K&K Mfg.  I believe they can re line them for you.
http://www.kkmfg.com/
Matt
Austin Tx
66 230 sl - "white"
78 300 D - Blue
98 C230
badali
  • USA, Pa, Butler
  • 1966 230SL
« Reply #3 on: March 06, 2016, 16:53:29 »
I had mine relined a few years ago and it was $132.  The company that did this for me was relining brakes for commercial vehicles in Pa.  You should be able to find one locally to you.  The classic center wanted $1000 for them new...
Brad
1961 220 Sb
1966 230 SL (Sold)
2019 E 450 4 Matic
2022 GLC 300 4 Matic
2025 E53 AMG Sedan
vande17941
  • USA, CA, Irvine
« Reply #4 on: March 06, 2016, 19:15:59 »
Looks like K&K shows them on their site, as mentioned earlier.
I wonder if I need to send them mine first, or if they send me a re-lined set, and THEN I send them back my cores. I don't really want to have to wait with the car sitting around.
« Reply #5 on: March 09, 2016, 00:01:03 »
I usually keep a relined set in stock. I use a better lining than stock with metalic fibers so they bite in better. I think the 230 uses a brake shoe that starts with a 110 part number. Check yours so I can be sure about the right ones.
vande17941
  • USA, CA, Irvine
« Reply #6 on: March 16, 2016, 13:24:09 »
After this brake shoe friction lining material separation, the inside of the brake drums are scored. Is there a minimum brake drum thickness that I need to be concerned about? And how is it measured ? Because these drums are definitely going to need to be machined on a lathe. Any info would be helpful. Thank you
