Author Topic: Exhaust resonator construction  (Read 6303 times)
vande17941
  • USA, CA, Irvine
« on: January 23, 2016, 23:08:48 »
I just replaced my muffler and it worked out well. I'd like to hear from anybody who has taken out a resonator and looked at the internals. Is it a baffle type system or a straight through insulated system?
'66 USA (1967 model Year) 230sl, 4-speed Manual, Driven Like a Real Car! Set up with KYB Stiffer Shocks, and Motor Mounts w Urethane Inserts Underneath, 3-point Belts, Headrests Installed 🚗
1986 560sl Cabernet & Palomino (not recommended)
2001 SLK320 Sport AMG Silver & Black
Re: Exhaust resonator construction
« Reply #1 on: January 24, 2016, 02:19:53 »
The original exhaust is straight through. The internal pipes are perforated with fiberglas sound deadening material surrounding. Works well, very little back pressure, but collects moisture. Baffle type mufflers and resonators are not correct for these cars.
Original systems are all weld-up, very difficult to install properly and they seldom are done correctly. A poorly installed exhaust can ruin the ride quality of the car. It takes me five to six hours to properly install an entire all weld up system these days. Mercedes changes suppliers from time  to time. Recently I got a factory new system from Mercedes for an early 230SL. The front pipes were about 1 1/2" too long making the exhaust hang down too far in the front. I had cut out a 1 1/2" section of each pipe and re-weld them before the system would hang correctly. We noticed that these parts were now being manufactured for Mercedes by Gillette.
« Reply #2 on: January 24, 2016, 07:08:20 »
The after market SS system I used recently had the exact same problem with the front pipes.  Seems they copy from each other. ::)
« Reply #3 on: January 26, 2016, 01:57:57 »
I welded the SS exhaust on my W111. And not being as skilled as the Dr. or Joe, it took me two days or better to make all of the adjustments. The exhaust on the Time valve is most definitely straight through w/ fiberglass. When the system was brand new, you could see a few strands of fiberglass on the rear bumper after a drive on the highway.
« Reply #4 on: January 27, 2016, 22:34:50 »
Oh, I didn't do the repair. I took it to a muffler shop and they did it. If I need to, I have a guy a half mile down the road who is a very talented welder. He's so good he can weld paper, or wood to glass.
  Half of being good at what you do is finding people who are even better at it than you are.
« Reply #5 on: January 28, 2016, 02:02:16 »
Quote
Wisely said Dan.
« Reply #6 on: January 28, 2016, 20:56:32 »
Really good welders (which I am not) are as amazing as very talented body men who use hammer and dollies. This one welder nearby welds parts for aerospace. One such part is a thin gauge ( 22 ga. or .030") aluminum that must be welded at an angle AND not show any distortions on the back side. Talk about heat control!
The best people at the top have even better people below them.
« Reply #7 on: January 28, 2016, 23:42:36 »
 Yeah, just ask my wife.   ;D
catjim813
« Reply #8 on: February 10, 2016, 02:51:01 »
Which system is better? the Ansa, rear and center mufflers from Parts Geek or the complete system from Time Valve?  longevity and quality of sound?
