Become a
Full Member
Emergency Contact List
PCV valve? Do these engine need one?
Topic: PCV valve? Do these engine need one? (Read 3399 times)
Pinder
Full Member
Platinum
USA, NJ, Edison
January 18, 2016, 22:20:51 »
My Valve cover vent hose is connected via a fitting that I thought was a PCV valve. I took the fitting off to make sure the PCV valve was working correctly, However it is just a plain old fitting no value. Do these cars need a PCV valve or not?
1970 280 SL Light Ivory DB 670. 4 Speed manual shift no AC Limited Slip Diff.
2015 BMW 320i xdrive
2021 Mercedes GLS450 Silver
Tyler S
Associate Member
Platinum
USA, CA, Encinitas
Re: PCV valve? Do these engine need one?
January 18, 2016, 22:43:31 »
No they don't. It is vented to an area before the throttle plate so there is no engine vacuum/ need for a PCV valve. Newer cars vent it to the intake manifold, necessitating a valve.
Pinder
Full Member
Platinum
USA, NJ, Edison
Reply #2 on:
January 19, 2016, 00:18:16 »
Thanks Tyler. Makes sense now.
Associate Member
Platinum
Canada, ON, Port Lambton
Reply #3 on:
January 19, 2016, 02:48:35 »
I would still vent it into the throttle valve like is supposed to be. Blow by fumes could be really bad at times and it would most likely be venting near your feet or knees depending on the length of hose used. You will get tired of smelling that quickly enough.
1966 230SL 5 speed, LSD, header pipes, 300SE distributor, ported, polished and balanced, AKA ''The Red Rocket ''
1970 3.5 Coupe
1961 190SL
1985 300CD Turbo Coupe
1981 300SD
2013 GMC Sierra
1965 230SL
