Author Topic: Exhaust pipe chrome muffler tips  (Read 5345 times)
vande17941
  • USA, CA, Irvine
« on: January 13, 2016, 03:51:55 »
Need to put a new rear muffler in. Can I remove my existing chrome tips, or are they welded on. I'd like to attach them to the new muffler, as they are in great shape. Any info appreciated. Thx.
'66 USA (1967 model Year) 230sl, 4-speed Manual, Driven Like a Real Car! Set up with KYB Stiffer Shocks, and Motor Mounts w Urethane Inserts Underneath, 3-point Belts, Headrests Installed 🚗
1986 560sl Cabernet & Palomino (not recommended)
2001 SLK320 Sport AMG Silver & Black
Re: Exhaust pipe chrome muffler tips
« Reply #1 on: January 13, 2016, 05:21:12 »
Normally they are just a friction fit. Rust makes them impossible to remove sometimes. Try warming them up all around with a propane torch, then try  to tap them off with a flat drift. Do not use so much heat that you dis-color the chrome.
« Reply #2 on: January 13, 2016, 10:12:45 »
An air hack saw is great for this job.
Cut off the tail pipes and then cut two slots the full length of the inside the remainder of the tailpipes, opposite each other. This will allow you to collapse what remains of the tail pipes and liberate the chrome tips for re-use without damage.
« Reply #3 on: January 13, 2016, 10:58:18 »
I assume an air hacksaw is not the same as an air guitar?
I have been known to wander around the garage looking for a spanner miming using it but an air spanner has yet to actually loosen any nuts. Well, not of the metal variety :o
Perhaps it's a qualified/experienced mechanic thing ;)
« Reply #4 on: January 13, 2016, 11:25:11 »
Personally I like to keep my air guitar in a state of open tuning in "D.
« Reply #5 on: January 13, 2016, 17:27:17 »
I keep mine in the key of '' F '' bomb.
felix
« Reply #6 on: January 18, 2016, 20:46:59 »
Here is a picture of the exhaust tips in my 1966 230SL
Iconic
  • USA, IL, Highland Park
  • ex-Membership Administrator
« Reply #7 on: January 26, 2016, 22:43:08 »
felix, I am missing your point. What are you trying to say?
Also, I've not seen any exhaust tips that look like those. But, I'm mainly a 280 SL guy... not a 230.
1998 BMW M-Rdstr Estoril Blue
« Reply #8 on: January 27, 2016, 10:23:13 »
Felix,
I agree with Mark. These are not MB tips.
As Joe said, the MB ones are friction fit. They have indentations so have yo be knocked on to the tail pipes.
Very difficult to remove once on, hence the suggestion to hacksaw the inner tail pipes in order to reuse them.
« Reply #9 on: January 28, 2016, 02:06:34 »
Felix, your muffler is installed up side down. The flat metal strap should be upward to provide a surface for the rubber bump stop. Also notice that your muffler is rubbing against the body sheet metal. It will wear a hole in the metal body of the car if it is left that way. Your tail pipes may also be contacting the bumper metal to metal since the rubber bump stop is not functioning.
« Last Edit: January 28, 2016, 02:11:27 by ja17 »
