Author Topic: Hand brake removal  (Read 5644 times)
RAY
Hand brake removal
« on: January 11, 2016, 18:27:35 »
I have just tried to remove my hand brake lever, disconnected the cable and the pivot bolt ok but when it came to undoing the main mounting bolt it would not shift.
Put a long extension bar on the ratchet and managed to turn it but still using a lot of force and it did not get any easier or seem to actually be undoing.
Any ideas as to whats happening, does it have a lock nut on the other side ?
Re: Hand brake removal
« Reply #1 on: January 11, 2016, 19:05:01 »
That bolt has left handed thread.
Turn clockwise to loosen.
« Reply #2 on: January 11, 2016, 23:55:00 »
In a situation like this where loosening the bolt as if it were RH threads doesn't yield success, I always carefully turn the other way just to see what happens. Only then I will go for a longer extension. In the case off bolt corrosion, it sometimes helps to budge a tiny bit tighter first. It seems to break up the corrosion instead of jamming it.
RAY
« Reply #3 on: January 12, 2016, 18:53:56 »
Thanks guys, cant believe it, never gave it a thought !
« Reply #4 on: January 12, 2016, 22:18:27 »
Story goes that what the public know as Q branch from the Bond films did sort of exist - Fleming would have known about it as he was the "right sort" to be a spook - have a read of Ben McIntyre's books (Operation Mincemeat is good)
As it happens, Q did develop canister type items with a screw lid that were RH threaded. Believing the enemy were so literal that they'd never think to "do it up" to open it
And said enemy have wreaked vengeance upon thee with a Pagoda handbrake ;D
Tyler S
  • USA, CA, Encinitas
« Reply #5 on: January 13, 2016, 02:46:09 »
Is this the only left hand thread fastener on the car except for the 4 linkage ball sockets?
« Reply #6 on: January 13, 2016, 17:25:04 »
No, there's also the tie rod ends on each side of the front suspension.
Tyler S
« Reply #7 on: January 14, 2016, 00:19:06 »
ahh yes, forgot about those. I guess the hard and soft top right front clasps could count as well.
Pinder
  • USA, NJ, Edison
« Reply #8 on: January 14, 2016, 14:33:41 »
and I discovered after stripping the throttle linkage rod that one end is also a LH fastner.
2015 BMW 320i xdrive
2021 Mercedes GLS450 Silver
