Author Topic: Help - Problem starting a 230SL (manual)  (Read 4432 times)
relbhcb
« on: January 05, 2016, 16:43:49 »
I can't get my 230SL's engine to start - after 2-3 years of never letting me down :( .
  • If I do not touch the throttle pedal and turn the key (after having let the fuel pump pressurise the system for ~10 seconds) then the engine fires for a couple of seconds at low RPM, but then dies - tick over is not self sustaining, and even if I "tickle" the pedal to keep it going the engine cuts out anyway.
  • Alternatively, if I press the throttle fully to the floor and turn the key then it roars in to life (maybe 2,500 RPM)  :o , but as soon as I try to reduce the RPM the engine dies.
  • If I do either of these more than two or three times I then have to leave it for ~10 minutes before it will fire again.
I had thought that the automatic choke required you to not touch the throttle during start, but the full-to-the-floor method was given to me to use if all else failed (& it did get me started last weekend).
Any suggestions as to what I can look at? The battery is fine, and the fuel tank is half full with reasonably fresh petrol. The electronic fuel pump sounds normal.
TIA
Re: Help - Problem starting a 230SL (manual)
« Reply #1 on: January 05, 2016, 16:48:40 »
Your engine isn't getting enough fuel which could be any number of problems. I would look at ignition first and then fuel pressure.
« Reply #2 on: January 05, 2016, 16:57:13 »
Ditto, on Dan's reply.
relbhcb
« Reply #3 on: January 05, 2016, 17:53:39 »
Thanks both; I have asked my independent MB specialist to come over on Friday to have a look at it - fuel issues (injection) are beyond me I'm afraid.  :-[
« Reply #4 on: January 06, 2016, 06:25:08 »
You need a good strong spark which you can check at the coil wire. Fuel volume is generally a sign of good fuel pressure. Both of these tests are on this site.
douglas5005
« Reply #5 on: January 22, 2016, 07:02:13 »
Any updates on the car?
« Reply #6 on: January 22, 2016, 16:31:14 »
Probably the warm up regulator on the IP. It could be stuck in the fully warmed position.
