Become a
Full Member
Emergency Contact List
Upper Control arm (outer) repair kit) which way does the washers go?
Topic: Upper Control arm (outer) repair kit) which way does the washers go? (Read 5406 times)
Pinder
Full Member
Platinum
USA, NJ, Edison
December 30, 2015, 21:42:53 »
Does anyone have a picture or diagram of the upper control arm (out) kit assembly order. Not sure which way the castle washer goes and on which side ?
1970 280 SL Light Ivory DB 670. 4 Speed manual shift no AC Limited Slip Diff.
2015 BMW 320i xdrive
2021 Mercedes GLS450 Silver
Associate Member
Platinum
Canada, ON, Port Lambton
Re: Upper Control arm (outer) repair kit) which way does the washers go?
December 30, 2015, 23:58:01 »
All of that info is readily available in the BBB.
1966 230SL 5 speed, LSD, header pipes, 300SE distributor, ported, polished and balanced, AKA ''The Red Rocket ''
1970 3.5 Coupe
1961 190SL
1985 300CD Turbo Coupe
1981 300SD
2013 GMC Sierra
1965 230SL
Pinder
Full Member
Platinum
USA, NJ, Edison
Reply #2 on:
December 31, 2015, 00:50:08 »
Ok. I've seen mention of the BBB. What is it and where does it live? I've looked through the index and done searches but not any closer to the where about of it.
Pinder
Full Member
Platinum
Australia, Victoria, Kyneton and Brisbane Queensland
Audit Committee
Reply #3 on:
December 31, 2015, 01:44:47 »
Pinder,
You need to search the Tech Manual for all information. Particularly as a Full Member you have full access to all areas. Most answers to questions are there
http://www.sl113.org/wiki/Documents/BBB
They come up here on the For Sale area occasionally and on eBay as well. Depending on what year you have you either need the first manual or both.
Last Edit: December 31, 2015, 01:49:22 by Garry
1972 MB 280CE W114 Auto RHD 906G
Associate Member
Platinum
Reply #4 on:
December 31, 2015, 03:19:02 »
BBB = big blue book 111 108 109 and 113 is fairly well covered in this volume.
I also use an earlier release for 230SL's that covers a number of models starting in 1959. One thing to remember with MB workshop manuals; you generally have to go back in years to find basic info that isn't covered in the BBB. In order to find the piston ring gap placement for a 280SL I had to go back to the 190 workshop manual before I could find it. Apparently, MB figures you should know stuff like that if you work at a dealership.
1970 3.5 Coupe
1961 190SL
1981 300SD
2013 GMC Sierra
1965 230SL
Associate Member
Platinum
USA, OH, Cleveland Heights
Reply #5 on:
January 01, 2016, 04:56:06 »
If you buy a BBB get a new reprint so you can read it in bed....Unless you are single.
Pinder
Full Member
Platinum
USA, NJ, Edison
Reply #6 on:
January 01, 2016, 21:26:13 »
Thanks! that's just what I needed. I think if I bought the BBB and started reading it in bed my wife will definitely beat me to a pulp using it as a weapon.She thinks I spend too much time on the car. In fact I secretly work on it when shes at work.
