with our official
Pagoda SL Group logo
from our official partner.
General Discussion
Control Shaft Connections
Topic: Control Shaft Connections (Read 4160 times)
mocstar
December 03, 2015, 22:48:10 »
Hi guys,
I had to drill out the two bolts connecting the control shaft to the air intake and can't seem to find these replacement bolts anywhere. (see attached pic)
Can someone point me in the right direction?
Much appreciated,
Matt
Full Member
Platinum
USA, OH, Blacklick
Re: Control Shaft Connections
December 05, 2015, 03:03:54 »
Yes these are centering bolts. They have a tapper under the head to center-up linkage position exactly. Try to order them the MB Dealer or Classic center. Otherwise find some good used ones.
Associate Member
Platinum
Canada, ON, Port Lambton
Reply #2 on:
December 05, 2015, 03:28:30 »
450SL ( and others ) manifold studs will work nicely. You will need to trim some of the threaded end off the longer portion to the correct length.
1966 230SL 5 speed, LSD, header pipes, 300SE distributor, ported, polished and balanced, AKA ''The Red Rocket ''
1970 3.5 Coupe
1961 190SL
1985 300CD Turbo Coupe
1981 300SD
2013 GMC Sierra
1965 230SL
mocstar
Reply #3 on:
December 08, 2015, 01:35:39 »
Thanks so much for your responses. You have saved me a lot of time.
Cheers,
Matt
General Discussion
