Please check out joining the
Emergency Contact List
for help during your travels!
Missing clutch parts
Topic: Missing clutch parts (Read 4380 times)
gordon
Associate Member
Senior
United Kingdom, England, Burntwood
December 03, 2015, 12:31:19 »
Hi, i am getting the parts together to convert my 230 from auto to manual. The pedal box i have is missing the clutch master cylinder push rod. I assume that it is a simple non adjustable rod with a boss on the end for the pivot pin to pass through.
Can anyone tell me what the dimensions are for me make a new one? [Thankyou all for help with previous questions] Gordon
Associate Member
Platinum
Canada, ON, Port Lambton
Re: Missing clutch parts
December 03, 2015, 20:47:20 »
I'm pretty sure that there's an eccentric to adjust free play on that rod. I would try to find a used rod which shouldn't be too hard to do.
1966 230SL 5 speed, LSD, header pipes, 300SE distributor, ported, polished and balanced, AKA ''The Red Rocket ''
1970 3.5 Coupe
1961 190SL
1985 300CD Turbo Coupe
1981 300SD
2013 GMC Sierra
1965 230SL
gordon
Associate Member
Senior
Reply #2 on:
December 04, 2015, 20:27:54 »
Yes, i have the pivot which is eccentric and appears to give approx 5mm of adjustment When the push rod is in place should it bear on the clutch piston, ie with no pedal travel before it displaces fluid?
Associate Member
Platinum
Reply #3 on:
December 05, 2015, 01:55:32 »
I imagine you would want a small amount of free play at the push rod as it rests in the piston so that the piston canl return to the rest position when you release the clutch.
1970 3.5 Coupe
1961 190SL
1981 300SD
2013 GMC Sierra
1965 230SL
Associate Member
Platinum
USA, OH, Cleveland Heights
Reply #4 on:
December 05, 2015, 02:47:15 »
I'm with Dan (Benz DR). It's really annoying fighting a clutch or brake master cylinder that doesn't return all the way.
gordon
Associate Member
Senior
Reply #5 on:
December 05, 2015, 09:01:30 »
Thankyou all, if i cant find a pushrod i will make one up bearing in mind your comments.
ctaylor738
Full Member
Platinum
USA, VA, Falls Church
Reply #6 on:
December 05, 2015, 15:37:51 »
PN 110 29018 39. A bit pricey at $114 list.
Chuck Taylor
1963 230SL #00133
1966 230SL #15274 (sold)
1970 280SL #14076 (sold)
Falls Church VA
