Author Topic: Replacing Headlight Bulbs  (Read 9379 times)
Mike K
« on: October 16, 2015, 17:23:39 »
Living in the countryside I've found the standard headlight bulbs too weak for night driving.
I've just replaced the bulbs and installed PHILIPS XTREME VISION  H4 http://www.philips.co.uk/c-p/12342XVB1/x-tremevision-car-headlight-bulb
All fairly straightforward, except that I had to experiment in order to find out which screws make the lateral and vertical adjustments.
For ease of reference I've attached some pics of which screws do what on the Euro lights:
Mike
Mike K
Re: Replacing Headlight Bulbs
« Reply #1 on: October 16, 2015, 17:31:40 »
On the left is the new Philips bulb and right is the standard bulb- prior to making vertical and horizontal adjustments.
« Reply #2 on: October 16, 2015, 20:39:57 »
Hi, Mike,
Did you use these bulbs with the H4 base (as in the Phillips site picture) or were you able to get ones with the P45t base?
« Last Edit: October 16, 2015, 20:48:42 by Naj »
Mike K
« Reply #3 on: October 17, 2015, 07:26:46 »
Hi Naj,
I could only find these bulbs in the H4 P43t base; checked the Osram as well, same story. I read somewhere that the new bulbs only come in the P43t base.
No problem fitting these, they have the 3 flat pins which overlap on the back of the reflector bowl, and then held in place with the spring clip.
Mike
jameshoward
« Reply #4 on: October 17, 2015, 08:27:28 »
Mike,
After leaving the lights on for a while, have you checked the temp of the lenses? I recall a discussion with a fellow member a few years ago about the possibility of the lenses cracking under the considerable heat. Grateful to hear what you found, (and check with the back of your hand!)
James Howard
1966 LHD 230SL
« Reply #5 on: October 17, 2015, 18:29:15 »
Hi Naj,
Mike
Hi, Mike,
To locate the H4 bulbs correctly, you need to use these adaptors.
Your local Renault club may be able to help?
http://www.volvosolutions.com/Misc_P45T.html
Hope this helps
Mike K
« Reply #6 on: October 17, 2015, 21:34:28 »
Mike,
Hi James,
The heat was something that concerned me when I fitted the new bulbs, and I did the "back of the hand test" against the lenses- the heat was not abnormal.
I drove the car tonight and tried the lights out for the first time at night, there's a huge difference in night vision! When I got home I left the lights on and checked the lenses with my hand again- no excessive heat.
On another note and in all seriousness  :o- we have a lot of wild boar around here, they're often on the roads at night and very difficult to see, often with near misses- I'm far more comfortable with these lights.
Mike
« Last Edit: October 18, 2015, 19:35:27 by Mike K »
Mike K
« Reply #7 on: October 17, 2015, 21:46:37 »
Hi, Mike,
Hope this helps
Hi Naj,
Thanks for the info, much appreciated! I'll check these adaptors out.
Mike
Mike K
« Reply #8 on: October 18, 2015, 14:19:08 »
Hi, Mike,
Hope this helps
What Naj pointed out above, re correctly locating/fixing the new H4 bulbs with the tabs, concerned me.
I made my own P43t to P45t adaptors by using a Dremel to remove the bases from the old H4 P45t lamps and making new incisions in the bases to accommodate the tabs.
Proper tight fit, the lamps won't move.
Mike
« Last Edit: October 18, 2015, 17:17:57 by Mike K »
« Reply #9 on: October 18, 2015, 18:45:21 »
Nice work  ;)
