Author Topic: front discs  (Read 4161 times)
Madmerc
front discs
« on: October 15, 2015, 09:11:12 »
hi all im working on all fronts on this 230sl going right thru it im up to the front disc brakes at the moment I purschased a new set of front discs as I pulled the old ones off I noticed the they were larger and ventelated to my surprize.
I found this number on the stubb axle 016276 and was wondering if any one could identify it . thanks
Re: front discs
« Reply #1 on: October 15, 2015, 11:15:19 »
If you've got ventilated discs then the chances are that someone has fitted front hubs from a v8.
Madmerc
Re: front discs
« Reply #2 on: October 15, 2015, 11:30:20 »
Hi stick no v8 in this one ever subframe all original down to the front hubs everything g is
Mercedes Maybe i think later model 280 sl front disks I don't no for sure  calipers are the same ate
And I've got another set of calipers and they are identicle
ctaylor738
  • USA, VA, Falls Church
Re: front discs
« Reply #3 on: October 16, 2015, 00:27:32 »
To the best of my knowledge, no ventilated discs in any Pagoda from the factory.  Very unclear to me how larger discs would fit with correct calipers.
Chuck Taylor
1963 230SL #00133
1966 230SL #15274 (sold)
1970 280SL #14076 (sold)
Falls Church VA
Re: front discs
« Reply #4 on: October 16, 2015, 00:45:14 »
W113 cars never came from the factory with ventilated discs. Check out the two photos and notice that the ventilated disc caliper is nearly 1/4" wider for the ventilated rotor......................................
« Last Edit: October 16, 2015, 00:50:39 by ja17 »
Re: front discs
« Reply #5 on: October 16, 2015, 06:04:52 »
Is there any real advantage to having vented rotors on a 113?
