with our official
Pagoda SL Group logo
from our official partner.
Drive Shaft Question
Topic: Drive Shaft Question (Read 4620 times)
vande17941
Associate Member
Senior
USA, CA, Irvine
October 08, 2015, 03:32:44 »
Had a "knowledgeable" W113 mechanic change the driveshaft middle support rubber bushing. Now it seems the shifter (manual) vibrates (and the car) like crazy at high speed. Is there anything that was needed to be removed or did the two halves of the drivesshaft have to be "matched up" in the same orientation? I'm looking for someone who has done this job and can tell me what it entails so I can either have him fix it right or do it myself. Thanks
'66 USA (1967 model Year) 230sl, 4-speed Manual, Driven Like a Real Car! Set up with KYB Stiffer Shocks, and Motor Mounts w Urethane Inserts Underneath, 3-point Belts, Headrests Installed 🚗
1986 560sl Cabernet & Palomino (not recommended)
2001 SLK320 Sport AMG Silver & Black
Full Member
Platinum
USA, OH, Blacklick
Re: Drive Shaft Question
October 08, 2015, 07:15:09 »
The drive shaft halves should always be marked before dis-assembly. Make sure that the drive shaft flex disc and centering is assembled correctly.
vande17941
Associate Member
Senior
USA, CA, Irvine
Reply #2 on:
October 08, 2015, 07:17:38 »
Thanks...that was my thought too...that he put the halves back together differently and the driveshaft is now out of balance.
What would the other things do that would be of concern...flex disc, centering etc?
Associate Member
Platinum
Canada, ON, Port Lambton
Reply #3 on:
October 08, 2015, 14:51:20 »
Check that the holes in the flange aren't worn. If the bolts came loose it can really wear the drive shaft and the flange on the trans out put shaft. If your guy didn't install a new hanger bearing I would do that. Any good bearing place will have that - maybe 15 bucks.
1966 230SL 5 speed, LSD, header pipes, 300SE distributor, ported, polished and balanced, AKA ''The Red Rocket ''
1970 3.5 Coupe
1961 190SL
1985 300CD Turbo Coupe
1981 300SD
2013 GMC Sierra
1965 230SL
mBdrvr
Full Member
Senior
USA, PA, Bethlehem
Reply #4 on:
October 08, 2015, 18:09:50 »
Another question regarding drive shafts:
Any suggestions on getting the two rusted halves apart?
Paul
Paul Greenblatt
'70 280 SL
'66 250 SE Cabrio
'60 190 SL
Associate Member
Platinum
Reply #5 on:
October 09, 2015, 01:20:32 »
oooooooohh......... that could be fun. I guess you could try a bit of heat on it. Make sure you keep the U joints cool if you do. Heat and then spary something like liquid wrench or similar on it while it's still warm. Tap it back and forth until it starts to move. Make sure you mark the halves so they go back together properly. I use anti seize so things like this won't happen.
1970 3.5 Coupe
1961 190SL
1981 300SD
2013 GMC Sierra
1965 230SL
