Author Topic: Brake Fluid Reservoir Removal  (Read 3833 times)
Raymond
  • USA, FL, Jacksonville
    • GemstoneMediaInc.com
« on: September 21, 2015, 02:11:04 »
Can anyone suggest a good method of prying the brake fluid reservoir off of the master cylinder without breaking it?   I don't know the age of the reservoir.  I last had it off the car 11 years ago.  I've pulled and pried on it with a fair amount force but the grommets won't let go.  I'm worried if I exert too much force I'll crack the tank or break out a nipple.
jameshoward
Re: Brake Fluid Reservoir Removal
« Reply #1 on: September 21, 2015, 08:31:19 »
You could try a bit of heat. It does come off, of course, but they can sit on there pretty tight. It's obviously far easier to do off the car.
James Howard
1966 LHD 230SL
Baybear
  • USA, VA, Midlothian
« Reply #2 on: September 21, 2015, 09:31:30 »
I use a trim removal tool that has a "Y" or "V" shaped end and pry it off.
Will
http://www.autozone.com/test-scan-and-specialty-tools/molding-and-trim-remover-tool
Will Milby
1970 300SEL 6.3, 1971 280SL, 1972 300SEL 4.5, 1972 Super Beetle, 1998 SL500, 2010 350 GLK, 2012 SLS AMG
Mike K
« Reply #3 on: September 21, 2015, 17:07:18 »
I recently did this using a long flat screw driver as a lever under/next to the grommets, popped right off.
