Author Topic: Separating the Transmission from the Engine  (Read 5209 times)
mBdrvr
  • USA, PA, Bethlehem
« on: September 04, 2015, 22:54:18 »
I've removed the engine and trans but I can't get the trans to separate from the engine. Any tips??
Paul Greenblatt
'70 280 SL
'66 250 SE Cabrio
'60 190 SL
Re: Separating the Transmission from the Engine
« Reply #1 on: September 06, 2015, 01:14:20 »
Make sure all of the bolts are removed. Sometimes things will corrode together and you might need to use a bit of heat on any suspected areas to aid removal. Normally the tans will come off easily so it seems odd to me that it won't come apart.
Is this a standard or auto?
mBdrvr
« Reply #2 on: September 07, 2015, 22:45:07 »
I missed some bolts. Thanks.
Paul Greenblatt
'70 280 SL
'66 250 SE Cabrio
'60 190 SL
