Author Topic: door striker plates in 67 found thanks all !  (Read 5622 times)
PMO956F
« on: August 11, 2015, 20:27:58 »
thanks to all , and to Eric who came up trumps - cheers.
Hi all
Ive been desperately looking for a pair for my 67 250sl  and have just  listed under wanted .. see the shaded out not available ones from the sls catalogue !
Does anyone know if this type were fitted to any other Mercedes as in 67 they seem to be different to any other w113
3 holes but flat plates without raised edges .  does anyone have any experience with  these ? why wonder did they change them so quickly ?!
Cheers
Darren
« Last Edit: August 23, 2015, 11:06:09 by PMO956F »
Re: door striker plates in 67
« Reply #1 on: August 11, 2015, 21:29:28 »
Take a look here: http://www.sls-hh-shop.de/en/230-280SL-W113/72-Door/72-b-Info-Door-Catch/
This shows all the different catches and what kind of alternatives exist.
« Last Edit: August 11, 2015, 21:34:01 by 66andBlue »
PMO956F
« Reply #2 on: August 12, 2015, 08:38:53 »
Hey thanks 66
yes been there there not available im afraid
Darren
« Reply #3 on: August 12, 2015, 15:56:08 »
Darren,
correct, but that is why people have replaced them with the 4-hole latches as shown in the diagram.
You need to drill a new pair of holes that is all.
PMO956F
« Reply #4 on: August 13, 2015, 22:25:21 »
Thanks for your reply
thats great news then, I hadn't realised that ! will get onto sls tomorrow .
Cheers Darren
« Reply #5 on: August 13, 2015, 22:35:59 »
Darren,
before you buy call SLS and ask whether they provide a template to drill the new holes.
It is not clear whether one pair (upper?) can be reused, or all four need to be drilled new.
« Reply #6 on: August 22, 2015, 05:32:35 »
110 sedans use the same type of latches. Rear doors are always the best choice if you can find them as they're seldom worn out.
PMO956F
« Reply #7 on: August 23, 2015, 11:04:25 »
thanks so much for the tip , happy now as found a pair !
thanks Again,  Darren
