Author Topic: Coil Question  (Read 5672 times)
Khurram Darugar
Coil Question
« on: July 09, 2015, 13:16:07 »
Hiya
Does anyone know if you take the middle wire (one coming from the coil) off the distributer cap and place it on the engine should the coil spark continuously or just once?  I'm getting one spark.
and nothing out of the 123 :(  Had to get the car towed home.
Upon recommendation from a local garage I'm running a 12V coil with no resister.  Coil is new as is the 123 unit.
Kay
Re: Coil Question
« Reply #1 on: July 10, 2015, 18:04:56 »
Yes, Kay,
Once every time you switch it off and then on.
Thats what the distributor does, switch the coil on and then off to produce the spark.
If you're not getting a spark at a plug lead from the 123 while cranking, that could be at fault?
Khurram Darugar
Re: Coil Question
« Reply #2 on: July 14, 2015, 12:42:52 »
Hi Naj,
Thanks I now know what the coil distributor relationship is :)
I have been in touch with 123 and they are going to service the unit.  They seem pretty helpful.
Here is a snippet from Frank's response which might be useful to the group.
"Some Mercedes coils have a very low primary resistance.
When the primary resistance of the coil is below 1,0 Ohm the ignition will be damaged."
Once back I'm going to try and time it myself!!  ;D
Kay
Re: Coil Question
« Reply #3 on: July 14, 2015, 13:10:02 »
So, what coil are you using?
Khurram Darugar
Re: Coil Question
« Reply #4 on: July 14, 2015, 17:46:45 »
Naj I running a brandless ebay job which has a stated resistance of 1.5 to 3.2 ohms.
Im thinking of going to a accuspark coil with resistance at 3ohms flat.  Other option would be to keep the same coil and add a 1 ohm ballast.
I will probably go with the accuspark.
Kay
450sl
Re: Coil Question
« Reply #5 on: July 14, 2015, 18:42:12 »
Kay,
I bought a 123 as well , during the installation the electronics in the unit went down , 123 replaced it as service.  123 ROCKS  :)
Khurram Darugar
Re: Coil Question
« Reply #6 on: October 19, 2015, 23:20:26 »
I just wanted to update this thread.
It took a bit of trying but in the end, the spring at the bottom of the 123 Ignition was too long.  It was pushing the distributor out, so it was out of sync.  Basically just chopped it in half and cars pretty stable now.
So in the end i learnt the hard way that spring really is a pain.
Kay
