Author Topic: rim & centre-hub paint combo  (Read 5441 times)
« on: September 30, 2004, 19:03:48 »
I am the lucky new owner of a '65 230SL - tan leather, euro lights, 4-speed, A/C, PS, PB
Question - with a red body & black hardtop, what is the proper colour combination for the steel rims and centre-hubcaps
- red rims w/black hub ? - red rim w/red hub ? - black rim w/red hub?
Re: rim & centre-hub paint combo
« Reply #1 on: September 30, 2004, 20:19:06 »
Every two tone car I have seen the hubcaps are the color of the roof.  Every 230sl I have seen the wheels are the color of the body.
« Last Edit: October 01, 2004, 21:06:24 by hauser »
« Reply #2 on: September 30, 2004, 22:33:28 »
Better look at the paint code tag on the inside of the fender. There's a 3 digit paint code number for the body and one for the hard top if the car has one. Some cars were sold without hard tops and your car could have a top from another car or someone may have painted it a different colour.
I prefer to paint the rims the same as the body which is correct. Some cars do have the caps the same as the hard top but here's a question for you, are you going to use the hard top very much? If not, I'd be inclined towards body colour for everything.
Daniel G Caron
« Reply #3 on: October 01, 2004, 04:30:10 »
Correct way is body coloured wheels and hardtop coloured caps on a 230SL!
'03 CLK Kompressor
« Reply #4 on: October 01, 2004, 09:59:14 »
Wheels on early cars were painted because of the small hub caps and beauty rings. a good picture as most of us have is the assemblie line with W113 SL showing the cars with out hub-caps and painted body color.
Later cars with full hubcaps the wheels got painted black. I would recommend powder coating the wheels .
« Reply #5 on: October 01, 2004, 11:53:04 »
Ditto that!  My Havana Brown 230SL with Light Beige hardtop has matching brown wheels with matching beige hubcaps.  In my case the Light Beige hubcaps also match the Cream Tex interior, so the car looks great with or without the hardtop. For what it's worth, the inner side of the wheels is a satin black.
I always thought that having the contrasting color hubcaps was a subtle way of being able to tell a car with two tops from one without the hardtop, as most early Pagodas seemed to have had contrasting hardtop colors.  More of the later cars went to body colored hardtops it seems, which makes it a little harder, on casual inspection, to tell if a later car is equipped with two tops in the summertime.
'03 CLK Kompressor
« Last Edit: October 01, 2004, 11:55:25 by Mike Hughes »
« Reply #6 on: October 01, 2004, 21:03:39 »
'03 CLK Kompressor
Yes, this is right.
« Reply #7 on: October 02, 2004, 09:04:45 »
Thanks for all the advise - body coloured rims it should be - as for caps, maybe Dr Benz has hinted at a solution for me - perhaps a set of black caps for April, May, and November to match the hardtop, and a set of Red caps for the summer months - maybe not correct, but why should women be the only ones to accessorize - now all I need to do is find a set of rims - Thanks again
