Author Topic: Becker Europa rear rubbber knob  (Read 4501 times)
jerrycastillo
« on: June 21, 2015, 02:01:26 »
Any idea what was the rubber knob attached to the rear of a Becker Europa (mono) used for? Perhaps instead of the rear plate that held the radio to the firewall?
Picture included.
Also, where should I connect the power?
Thank you!
Gerardo
1970 280SL horizon blue
Re: Becker Europa rear rubbber knob
« Reply #1 on: June 21, 2015, 02:33:19 »
Gerardo,
that rubber knob is used for mounting the radio in the dash .. but not in Pagodas; you can take it off and sell it.  ;)
The recommended way to power the radio is through a fuse box in the engine bay on the passenger side as described in the technical manual:
http://www.sl113.org/wiki/Electrical/Radio#RadioInstall
You should have a red/green wire in the harness already to power a fuse box as discussed here:
http://www.sl113.org/forums/index.php?topic=17189
If you do not have that wire then you need to run a new one either from the alternator as described here: http://www.sl113.org/forums/index.php?topic=7537.0
or from fuse #1 in the fuse box or pole 30 on the light switch under the dash.
scoot
  • USA, CA, Altadena
« Reply #2 on: June 21, 2015, 13:14:48 »
Yeah, what Alfred said.   The rubber knob is the attachment/alignment pin for use in W114/W115 cars.   I don't think it is used in any other MBs, but it might be used in early W123 or W116 cars.  Not used in W111, 113, 108, 109 cars.
Scott Allen
'67 250 SL (early)
Altadena, California
jerrycastillo
« Reply #3 on: June 21, 2015, 17:42:45 »
Thank you Alfred, Scott for your replies!  :) :)
Gerardo
1970 280SL Horizon Blue
