Author Topic: Soft top frame stripped - is there a fix?  (Read 5711 times)
dakman29
  • USA, WA, Spokane
« on: June 06, 2015, 17:11:58 »
Apologies if this has been covered but I am having an issue with my soft top frame.  It's been a constant battle to keep all of the connection points tight but most recently I had one of the flat top bolt/screws pop out of the frame. There are only two flat tops as far as I know and this one is on the driver's side.  This is the connection where when the top is up the connection point is hidden behind another, thus the need for the flat top bolt/screw.  In trying to reattach I find that the point that the bolt/screw threads into may be stripped as the screw goes in but won't tighten down and just pops out again. I tried just screwing the bolt into the connection point without going through the hinged bar firs just to test it and as I said it just spins and won't bite.  I tried another screw to see if that was the problem, but same result.  Is there a fix that anyone knows of short of a new soft top frame?  Thanks.
Re: Soft top frame stripped - is there a fix?
« Reply #1 on: June 06, 2015, 17:46:32 »
I would tap a larger bolt hole and either search for a matching bolt or have that specially made. That ought to work fine. Other than that, helicoil or other fixes are also possible I imagine, such as wleding the hole shut and then tapping the correct size hole back in.
sandcrab59
  • USA, MA, Lunenburg
« Reply #2 on: June 06, 2015, 20:07:13 »
dakman:
Call or email Gernold in Maine. he might answer your question.
He repairs the frames all the time, I have personally watched him work.
Fantastic work but expensive.
Email:
sltechw113.com
Tel # 207-985-3001
Tell him Tom Mrowka said to call.
71 280SL-8  Euro
67 250 SL
72 220 D
1982 300 SD
1983 300SD
1985 300SD
1931 Model A Ford Roadster
1997 Corvette C5
« Reply #3 on: June 07, 2015, 19:55:21 »
Use a time cert to repair the thread. Kits are expensive so you might have to find someone to do it for you but should only take 30 mins.
tel76
« Reply #4 on: June 08, 2015, 08:34:33 »
I used a Heli coil to repair the mine, they are not expensive and do the job.
Eric
Jack Jones
  • Canada, ON, Milton
« Reply #5 on: June 09, 2015, 00:31:34 »
A Time-Sert is more expensive but for good reason, it is a one time repair when done correctly. Helicoils can pull out and for this reason Time-Sert even makes oversize kits to repair failed Helicoils.
Jack Jones
1970 280SL 4 Speed
1984 280SL 5 Speed
tel76
« Reply #6 on: June 09, 2015, 08:33:37 »
In this particular application a Heli-coil is sufficient, you would not over tighten the screw and pull out the Heli-coil with a screw driver.
Eric
dakman29
  • USA, WA, Spokane
« Reply #7 on: June 09, 2015, 18:06:01 »
Thanks to all for the responses.  Very helpful.  This forum never fails to come through.
