Author Topic: Need a new or rebuild cylinder head  (Read 6395 times)
Lizzy
« on: April 11, 2015, 16:39:49 »
Have a 1968 280sl standard.  In the middle of a rebuild need a new or rebuild head, I'm in Ontario Canada.  just gotta get done summers commin'! don't want to miss the while season. Anyone have any suggestions?
Dave H
  • United Kingdom, England, Durham
    • Dave H
Mercedes 250SL    1967
Mercedes 250SLK  2014
Alfa Romeo 166 3.2 Ti
Fiat 500
Re: Need a new or rebuild cylinder head
« Reply #2 on: April 12, 2015, 12:46:25 »
Lizzy, please provide the casting number on the side of the cylinder head (below the spark plugs). There are different heads  and not all are interchangeable.
tel76
« Reply #3 on: April 12, 2015, 14:52:13 »
Neither of the above cylinder heads are suitable for the injected 280sl engine.
Eric
« Reply #4 on: April 12, 2015, 16:03:09 »
I might have something. I'll look and PM you.
« Reply #5 on: April 13, 2015, 02:57:45 »
Dave,
Both the heads you show are for carbureted engines and will not work.
Dave H
    • Dave H
« Reply #6 on: April 13, 2015, 07:13:52 »
Thanks Joe / Tel
One seller says it fits the w113.
The other says it fits M130 with modification.
Now you point this out the difference is quite clear.
Where are the drilled fuel injector tapped holes and the recess cast into the head at these locations.
Some modification indeed.
I wonder if if somebodys even tried it
« Last Edit: April 13, 2015, 08:46:30 by Dave H »
Mercedes 250SL    1967
Fiat 500
tel76
« Reply #7 on: April 13, 2015, 07:40:44 »
There are no holes for the injectors.
Eric
« Reply #8 on: April 13, 2015, 13:18:41 »
The injected engine blocks are wider in the front chain gallery area. As a result the fuel injected heads are wider in the chain gallery area. Note there is a chain sprocket missing in the chain gallery of the head of the carbureted engine since there is no room for it. Also with the injected heads the valve cover surface on the manifold side is serpentine-like (curves). It is straight with carbureted heads. Earlier MB injected engines (220SE) with injectors mounted in the intake manifold did have a straight valve cover on both sides, but the heads were still wider at the chain gallery since their blocks were also wider in the front to accommodate the distributor and fuel injection pump. A carbureted head will not work on a W113 engine.
Lizzy
« Reply #9 on: April 29, 2015, 13:02:00 »
Sorry everyone, been so caught up in moving houses i havent had a chance to get back to this forum.  the car is in getting some other stuff done i will get the numbers off the side i think i rebuild is the best option >gulp<
