Author Topic: Glue Remover for Carpet  (Read 4485 times)
Wes Bender
« on: February 27, 2015, 20:55:21 »
I'm replacing the door threshold trim and I need to loosen the carpet glue so that I can access the screws on the inner trim piece.  I don't mind bending the trim pieces open to access the carpet therein, but I can't afford to ruin the carpet.  It is the original Forest Green on this '70 280SL and apparently is made of unobtainium.
I'd like to know what others have used successfully.  I found one older post that recommended Ados Glue Remover but I believe that was from NZ and I can't source it here in the U.S.   Thanks in advance for any suggestions.
Wes
Re: Glue Remover for Carpet
« Reply #1 on: February 28, 2015, 00:28:07 »
Try some lacquer thinner in a spritzer. Pry up one edge and spray the adhesive as you peel the carpet away.
TOMNISTUFF
  • Canada, Qc, Levis
« Reply #2 on: February 28, 2015, 02:35:42 »
Since I'm starting to reinstall my carpet very soon, this is a great subject.  Joe, can the Lacquer Thinner be spritzed on the square weave side of the carpet to gently dissolve and remove what looks like a dried glue spill during carpet installation back in the 1990s.  Fortunately, I didn't need glue remover to remove the carpets, but I don't really want to put the passenger door sill carpet back with an old ugly glue stain on it.  By the same token, I don't want to completely destroy that piece of carpet.
Any suggestions?  The carpet is still out of the car, so it's accessible to work on comfortably.
Tom Kizer
« Reply #3 on: February 28, 2015, 07:18:54 »
Hi Tom,
Never tried it that way. Not sure if it would liquefy the carpet dye or not.
Wes Bender
« Reply #4 on: February 28, 2015, 15:21:17 »
Thanks Joe.  I'll give that a shot.
Wes
« Reply #5 on: February 28, 2015, 18:40:51 »
Just be careful with the spritzing!! Lacquer thinner is flammable!
