Author Topic: Brake and Clutch pedal rubber pad  (Read 3698 times)
bkksl
« on: February 06, 2015, 09:28:16 »
Does anyone know if the rubber pad for brake and clutch are exactly the same?   I see that the brake pad has long rubber downward extension on the right side the pad. Is clutch rubber pad suppose to be the same or just flat rubber pad?
jpinet
Re: Brake and Clutch pedal rubber pad
« Reply #1 on: February 06, 2015, 15:10:33 »
Clutch and brake pedal rubbers are the same.
They are hard to install. I found that heating my rubbers in the oven made them soft enough to install with relative ease. Hot water is not hot enough.
450sl
« Reply #2 on: February 06, 2015, 15:38:10 »
the picture is a autobrake pad      the manual brake-clutch pads where nla ..
