Author Topic: Missing Rear License Plate Lights  (Read 7542 times)
RobSirg
« on: January 05, 2015, 12:37:18 »
Guys,
I just noticed that neither of my 280SL's have the rear license plate light in place. Doesn't seem to be a lot of space there as I can see the underside of a rubber seal filling the space(see photo). Can it still fit?
Is it purely coincidental that both cars are missing the lights or is there some other reason? (until now I thought they were only specific to US cars, like the side markers, but I saw and Aust. car yesterday with them fitted).
Thankfully I see the complete kits are available.
Rob
« Last Edit: January 05, 2015, 12:42:21 by RobSirg »
1962 E Type Jag BRG with Tan
1974 White Alfa Spider 2000
2023 Range Rover
1982 280TE (my daily)
1977 Yellow 911 Targa
1991 Nissan Figaro
1959 190SL Black
1970 300SEL 3.5
mmizesko
  • USA, OH, New Albany
Re: Missing Rear License Plate Lights
« Reply #1 on: January 05, 2015, 14:48:24 »
Rob, those are the lights.  The rubber is a blind that directs the light down toward the plate only, and not in the eyes of the following car.  You can see the plastic lens behind the rubber guard.
Get into the trunk  open the square hatches on the wall next to the lock, undo the small bolts from the outside, pull the harness back through the holes into the trunk, open the casing, and replace the big double ended (not sure what you call them?) bulbs.  Should be fine.
Mike Mizesko
Columbus, OH
1970 280SL 291H Dark Olive
RobSirg
« Reply #2 on: January 05, 2015, 22:11:48 »
Thanks Mike,
Your answer pleases me greatly ......and slightly embarrasses me :D
I will give them a clean up - should be a fun mini project.
Now that I think about it - the example I saw that got me wondering was missing the rubber blind.
Cheers
Rob
2023 Range Rover
1991 Nissan Figaro
1959 190SL Black
1970 300SEL 3.5
mmizesko
« Reply #3 on: January 06, 2015, 01:21:33 »
Rob,
No worries.  I've had mine out a couple of times.  There are places in my car I've never been.  All relative.  Noticed that your rubber has paint on it, so the painter didn't take them out on the last paint job.  They'll clean up easy with some solvent.
But being down under, just make sure the rubber doesn't go the opposite way from up here! :D
Best of luck, and keep using the site, I've seen lots of your posts.  Saved me lots of time and heartache.
Mike Mizesko
Columbus, OH USA
RobSirg
« Reply #4 on: January 06, 2015, 08:30:34 »
Thanks Mike,
I saw the paint also - not sure if it was the Respray I commissioned or the many beforehand. I'm somewhat thankful they left the rubbers in place - at least that way they didn't lose or break them.
Cheers
Rob
2023 Range Rover
1991 Nissan Figaro
1959 190SL Black
1970 300SEL 3.5
450sl
« Reply #5 on: January 06, 2015, 10:36:25 »
Solvent can destroy them :  so be careful
