Author Topic: m127: No oil pressure  (Read 16703 times)
pagodarune
  • Norway, Ostfold, Trogstad
Re: m127: No oil pressure
« Reply #25 on: February 24, 2015, 17:12:47 »
My distributor gear is not coming off with ease. I tried to tap it lightly with a rubber mallet, but it is still stuck at the shaft. I am afraid of damage anything, so I do not want to use a lot of force. Do I need to get myself a tool as shown in the attached picture?
Rune R
1966 230SL
« Reply #26 on: March 01, 2015, 22:28:25 »
How are you planning to get that puller into that small work area?
pagodarune
« Reply #27 on: March 02, 2015, 17:36:02 »
I used a puller with grip width 6-35mm, and it got a grip behind the gear. Very little force was needed to remove the gear. Both the woodruff key and sprocket came off with no problem.
Rune R
1966 230SL
« Reply #28 on: March 02, 2015, 21:41:33 »
You out smarted me. ;D ;D
pagodarune
« Reply #29 on: March 09, 2015, 21:07:17 »
Update: The engine is now diassembled. It is visible wear at the intermediate shaft and vertical shaft driving the oil pump and tach.
I have also taken out the pistons and crankshaft. The rod bearings and main bearings have survived, see pictures.
Rune R
1966 230SL
