with our official
Pagoda SL Group logo
from our official partner.
Electrical and Instruments
key -- anyone know what it's for?
Topic: key -- anyone know what it's for? (Read 7808 times)
kampala
Full Member
Platinum
USA, CA, Hermosa Beach
November 12, 2014, 05:21:42 »
I was removing the glove box to get access to the clock and found this key & this radio tag. Anyone recognize this key and what it might be for? See photos. The tag must be for the radio as the car has a Blaupunkt --- I don't know if the key is related to the radio. Would appreciate your thoughts.
250sl - later - manual
280sl - 1971 - Auto - LSD
Full Member
Platinum
USA, CA, Fallbrook
Re: key -- anyone know what it's for?
November 12, 2014, 05:43:44 »
Could it be for the antenna, to pull it up from when it's completely retracted?
nirmal
Reply #2 on:
November 12, 2014, 05:46:47 »
This is a key for manual car antenna.
Nirmal
1969 280 sl
nirmal
Reply #3 on:
November 12, 2014, 05:50:40 »
The link below will give you all the information you need.
http://mgaguru.com/mgtech/accessories/at112g.htm
Nirmal
1969 280 sl
1953 MG TD
2012 Jaguar XJ
kampala
Full Member
Platinum
Reply #4 on:
November 12, 2014, 11:53:25 »
Very much appreciated. Thanks!
Jordan
Full Member
Platinum
Canada, ON, Jordan
Reply #5 on:
November 12, 2014, 13:12:38 »
The tag would normally be on the side of the radio. Glue must have dried up and it fell off. The E suggests the radio is from the early/mid '70's, probably '73.
Marcus
66 230SL Euro 4 speed
KevinC
Reply #6 on:
November 12, 2014, 16:57:23 »
When new, it would have been attached to a ring and a small booklet like this one ...
kampala
Full Member
Platinum
Reply #7 on:
November 13, 2014, 05:01:19 »
interesting details --- great stuff.
Appreciated.
Garland
Reply #8 on:
December 02, 2014, 22:45:51 »
You are correct. The Benz antenna had a wite plug at the end with two notches/gaps spaced 180 degrees apart. The key you show fits into the notches to liberate the antenna tip from its snug storage level on the fender. RIc Garland,Montreal,Canada
