Author Topic: Limited Slip Differential Oil - Special Oil?  (Read 5766 times)
kampala
  • USA, CA, Hermosa Beach
« on: July 19, 2014, 00:29:05 »
I am a little confused about the special oil for a Limited Slip Differential.  My local MB dealer could not advise on which oil to use so I got it from the classic center -- they said the correct oil for the LSD is part number A 001-989-33-03-12.
My local mechanic, who was going to change the diff oil for me as it's not easy without a proper lift, asked me to get the special oil and he'll do the change.  Admittedly he's not a specialist on these cars as he works on modern mercedes, however, when I showed him this oil, he wanted me to double check as he is surprised that the weight is so close to standard diff oil.  This mercedes oil is described as: Differential Oil; Hypoid Gear Oil; SAE 75W85.
Also I have read that this oil is a replacement for a no longer avail oil.
Can someone advise if I have the correct oil for a Limited Slip Diff?
Any help would be appreciated.
« Last Edit: July 19, 2014, 04:28:44 by kampala »
250sl - later - manual
280sl - 1971 - Auto - LSD
Re: Limited Slip Differential Oil - Special Oil?
« Reply #1 on: July 19, 2014, 08:48:36 »
I use veedol LS90
sandcrab59
  • USA, MA, Lunenburg
« Reply #2 on: July 20, 2014, 00:43:44 »
Ask JA17.
Joe  will know the correct oil.
Tom Mrowka
71 280SL-8  Euro
67 250 SL
72 220 D
1982 300 SD
1983 300SD
1985 300SD
1931 Model A Ford Roadster
1997 Corvette C5
« Reply #3 on: July 20, 2014, 01:19:09 »
Dan C, Benz Dr also runs a LSD in his Pagoda so would be a good source of oil recommendation.
kampala
« Reply #4 on: July 20, 2014, 15:32:32 »
Thanks all - appreciated.  Since I'm in California with the car, I can't seem to find the Veedol locally.
Bonnyboy
  • Canada, BC, North Vancouver
  • 1969 280sl Euro 4sp LSD
« Reply #5 on: July 21, 2014, 03:24:11 »
After much discussion I went to the Mercedes shop and bought the LSD oil that they sell.  The part number seemed to be for a much newer car but the mechanics said it was the right stuff for my old girl.  Definitely not cheap though.
Ian
69 280SL
73 CB750K
75 MGB
78 FLH
82 CB750SC
83 VF 1100C
94 FLHTCU
96 F-150
08 NPS50
12 Pro 4X
