Author Topic: side moulding rubber insert cutting?  (Read 5299 times)
Rick
  • USA, NV, Gardnerville
« on: June 10, 2014, 15:01:18 »
I will be installing replacement black body side rubber strips into the chrome body side mouldings.   What is the proper way to shape / cut the ends of these black rubber inserts? Should the rubber at the ends of the inserts be cut straight  or was it cut with an inward angle of sorts?
KevinC
Re: side moulding rubber insert cutting?
« Reply #1 on: June 10, 2014, 15:10:20 »
I cut mine with a single sharp razor on a slight angle. There is likely to be a better way but it worked just fine for me.
49er
  • USA, CA, El Dorado Hills
« Reply #2 on: June 10, 2014, 15:48:12 »
Here are some photos of mine, front to back. The rear rubber strip is cut on the same angle on both ends
1969 280SL 003820
4 speed manual, PS. 77K+miles
« Reply #3 on: June 15, 2014, 21:47:03 »
Yes depending on the location, they are cut at various angles. A bit of soapy water along with a sharp blade or razor will create a clean cut.
scoot
  • USA, CA, Altadena
« Reply #4 on: June 16, 2014, 03:25:06 »
We need to install this in our car also.  Is it easier to install if the rubber has been sitting in warm water or something to make it softer?  Any tricks or hints?   Thanks
Scott Allen
'67 250 SL (early)
Altadena, California
« Reply #5 on: June 16, 2014, 04:15:42 »
I found the easiest way to insert the rubber strip was to put the upper edge in first and then with a wide flat end screwdriver, gently push the lower side into the moulding, working along the strip from one end.  Be careful pressing on the screwdriver to avoid damaging the rubber but also slipping off and damaging paintwork. Working form the bottom also lessens the risk of any possible marking on the rubber being visible. I did not use any lubricating. If is new rubber then it has some malleability to it. Warming it certainly will help
 It is a slow process but once you get the hang of it then it gets faster.
jpinet
« Reply #6 on: June 16, 2014, 04:29:13 »
I've put mine in the oven at 140F to warm them up. They became much softer and were easier to install. I didn't think of hot water, but I guess that could work also. Yes, as others mentioned, there are cut at an angle. It is necessary in the front to clear the fender edge, in my car anyway, and I guess MB cut the back part to make it look alike.
