Author Topic: Geometry set up 230 1966. what are the details/specs please?  (Read 4927 times)
Paul99
  • 230 SL White. 1966.
Could someone let me have the right setup specs for my 230 1966 RHD Auto power steering please?
IE : Toe in front and rear, Camber front and rear, front Caster. Ride height etc.
Many thanks.
Paul.
jpinet
Re: Geometry set up 230 1966. what are the details/specs please?
« Reply #1 on: May 24, 2014, 10:36:42 »
I'd love to get these specs too!
Can I assume they are the same regardless if the car is left or right-hand drive?
DaveB
« Reply #2 on: May 25, 2014, 15:05:06 »
1966 Technical data book lists
toe in front: 2±1mm or 0° 20’± 10’
permissible toe in (+) or toe out (-) rear: 0 ±2mm or 0° ±20’
caster (power steering): 4° ± 15’ (mechanical steering 3° 30' ± 15’)
camber front (curb condition): +0° 10’ +20’ (at test load, 2 x 65kg in front seats, 0°+20’)
camber rear (axle load 650kg): +1° 45' ± 30’
There's probably something in there on ride height but I can't immediately see it. It has been discussed here though.
DaveB
'65 US 230sl 4-speed, DB190
Paul99
« Reply #3 on: May 26, 2014, 15:10:56 »
Thanks Dave. Getting it sorted next weekend I hope.
scoot
  • USA, CA, Altadena
« Reply #4 on: May 26, 2014, 20:44:19 »
Are those things in the BBB?  If so I'm happy to look it up.  I don't think ride height is going to be in there...
Scott Allen
'67 250 SL (early)
Altadena, California
TOMNISTUFF
  • Canada, Qc, Levis
« Reply #5 on: May 26, 2014, 22:09:05 »
They are both in the BBB.
Front ride height is determined by the heights of the inner and outer lower control arm axes and is shown on page 40-0/3, with the sketch describing it in figure 40-3/15 on page 40-3/11.
Rear ride height is determined apparently by rear wheel camber and is shown on page 40-0/4.
I've never done that yet.  I'll burn that bridge when I get to it.
Tom Kizer
