with our official
Pagoda SL Group logo
from our official partner.
General Discussion
250SL 5 speed
Topic: 250SL 5 speed (Read 6509 times)
mgandrew
Full Member
Junior Level
USA, OH, Granville
1967 250 SL 4 speed
250SL 5 speed
January 15, 2014, 02:28:29 »
Tell me what you know.
This car has had some body work. No fender spot welds, no paint runs under the hood (bonnet). A mediocre respray some years ago.
Some rust in each foot well.
Honorary Member
Platinum
Re: 250SL 5 speed
January 15, 2014, 10:12:42 »
…and your question is?
I'd recommend reading a bit more before asking…
Vendor
Platinum
United Kingdom, England, Richmond
Re: 250SL 5 speed
Reply #2 on:
January 15, 2014, 16:04:23 »
I've had a look into my crystal ball and I reckon it's worth about 10k.
Stick
www.colinferns.com
Flyair
Full Member
Platinum
Poland, Mazowieckie, Konstancin Jeziorna
Re: 250SL 5 speed
Reply #3 on:
January 15, 2014, 17:36:16 »
To tell what I know... I am afraid I may know too much, so I prefer to remain silent, so it cannot be used against me
Stan
2011 SL550 AMG
2011 GL
2015 GLA
garymand
Re: 250SL 5 speed
Reply #4 on:
January 15, 2014, 18:22:42 »
Well...you are correct about the lack of paint runs, spot welds, You know more than most.
67w113
Re: 250SL 5 speed
Reply #5 on:
January 15, 2014, 19:50:43 »
I'll play alog..hmmmm does it have the fender notches for headlights?
Jack Jones
Full Member
Silver
Canada, ON, Milton
Re: 250SL 5 speed
Reply #6 on:
January 15, 2014, 20:09:17 »
Can you provide an audio track of the engine running?
Jack Jones
1970 280SL 4 Speed
1984 280SL 5 Speed
Rodolfo
Re: 250SL 5 speed
Reply #7 on:
January 15, 2014, 23:58:54 »
it will most likely be the left side.That is often the case with these cars .
mgandrew
Full Member
Junior Level
USA, OH, Granville
1967 250 SL 4 speed
Re: 250SL 5 speed
Reply #8 on:
January 17, 2014, 17:50:23 »
The car doesn't run. Turns over quite well. Siphoned the tank to check the gas. It's the color of varnish. No wonder. It,s going to a shop to have all fluids changed including a flush of the fuel system. That should do it. I have some receipts for some serious work. Fuel injection pump being one of them. It has a very new looking soft top but I don't think it had ever been dropped into it's home behind the cockpit, because when I tried to do it wouldn't go down all the way. Have to work on that. My 280SL had it's hard top removed when I brought it home and the soft top was only up to support the cover in winter and if I got caught in the rain. Probably will do the same thing here. My 280SL had hardened valve seats. This one doesn't. Any consensus on the use of fuel additives?
jameshoward
Associate Member
Platinum
United States, New Jersey (formerly of London)
Re: 250SL 5 speed
Reply #9 on:
January 17, 2014, 18:12:33 »
Photos!
And go to the wiki. Unless your 'shop' knows the cars well, it may pay you to take some printed matter to the mechanic. There's some sterling advice on getting a non-runner prep'd for starting, then servicing, etc.
James Howard
1966 LHD 230SL
W113SL
Re: 250SL 5 speed
Reply #10 on:
January 23, 2014, 23:36:30 »
James: I just finished re-commissioning a 250SL that sat for 15 yers. I was lucky as the fuel system was fine. Needed brakes all hoses and a major tune up.
I live in Aurora Ohio. If that's near you, I could come and take a look.
BTW, all SL's have aluminum heads so they all had hardened seats in the head.
Pete Lesler
W113SL
mgandrew
Full Member
Junior Level
USA, OH, Granville
1967 250 SL 4 speed
Re: 250SL 5 speed
Reply #11 on:
March 23, 2014, 15:22:06 »
Update, Runs, thanks to some advice from Joe Alexander. Test drive resulted in a rather loose shifter. I found all 6 gears but 2nd to 3rd was not so easy. Bushings ordered. Should be here this week.
General Discussion
250SL 5 speed
