with our official
Pagoda SL Group logo
from our official partner.
Cooling Tank Level Label for 230SL and Early 250SL
Topic: Cooling Tank Level Label for 230SL and Early 250SL (Read 4777 times)
Rolf-Dieter ✝︎
Associate Member
Platinum
Canada, ON, London
December 15, 2013, 00:58:31 »
I saw quite a few questions on engine overheating and what the water level should be in the COOLANT TANK. I came across this label and it shows 4 cm from the top to the cold water level. I thought I share this with you including the label
The Description denotes it to be for the 230SL & Early 250SL Coolant Tank. If nothing else it shows us from what point we should measure the cold water level.
I recommend that each of us check there manual since it only mentions the 230 and early 250SL
Label/Decal Translation;-
Kaltwasserstand: ---> Cold water level
Überdruck-Kühlsystem ---> Over-pressure cooling system)
Deckel mit Kennzahl 100 Öffnen nur unterhalb 90 C Überdruck auf Raste I abblasen lassen. ---> Only open the lid with code 100 when temperature is below 90 C let positive pressure bleed off with catch at position I.
Schließen auf Anschlag (Raste II) ---> Close to stop (notch II)
Last Edit: December 15, 2013, 01:02:49 by Rolf-Dieter
Rolf-Dieter ✝︎
Associate Member
Platinum
Canada, ON, London
Re: Cooling Tank Level Label for 230SL and Early 250SL
October 10, 2016, 16:14:19 »
Does anyone know what the measurement for a 280 sl should be? Or is it the same 4 cm ?
yves
Full Member
Silver
France, Poitou-Charentes
Happy owner of a 69/ 280 sl , 63 Etype ,55 XK 140
Re: Cooling Tank Level Label for 280 sl
Reply #2 on:
June 02, 2018, 16:25:07 »
Hello everyone here, i am filling my coolant tank and doesn't know the right level in the tank. I have read somewhere that it is 4 cm from the top of the tank for an early 250 and wonder if it is the same for a 280 ?
Happy owner of a 69 blue 280SL , 63 FHC osb E-type , 55 FHC XK 140 to be restored...
Associate Member
Platinum
Canada, ON, Port Lambton
Reply #3 on:
June 03, 2018, 07:37:52 »
I usually fill the 280SL coolant tank from about 1/2 to 2/3 full.
We had a pressure gauge on the 230SL today and it never ran more than 7 PSI even when it started to run hotter while waiting in line to enter the show so I know everything is OK.
1966 230SL 5 speed, LSD, header pipes, 300SE distributor, ported, polished and balanced, AKA ''The Red Rocket ''
1970 3.5 Coupe
1961 190SL
1985 300CD Turbo Coupe
1981 300SD
2013 GMC Sierra
1965 230SL
