Author Topic: Light and difficulty downshifting into 1st  (Read 6190 times)
Louiehenry
« on: December 03, 2013, 16:16:45 »
I've noticed recently, when going from second to first and braking, the gearbox seems to be fighting me, it's not grinding, nor whirring, it just doesn't want to engage first! When it finally does, the top light on the cluster flickers on and off. What does the light mean? It's a 71 280sl.
Louiehenry
Problems engaging first
« Reply #1 on: December 03, 2013, 16:17:34 »
I've noticed recently, when going from second to first and braking, the gearbox seems to be fighting me, it's not grinding, nor whirring, it just doesn't want to engage first! When it finally does, the top light on the cluster flickers on and off. It's a 71 280sl.
Re: Light and difficulty downshifting into 1st
« Reply #2 on: December 03, 2013, 23:46:38 »
Start off by checking the fluid level.
Louiehenry
« Reply #3 on: December 04, 2013, 07:21:24 »
Which fluids?
« Reply #4 on: December 05, 2013, 14:28:03 »
Dextron or the modern derivative is fine.
garymand
« Reply #5 on: December 13, 2013, 19:47:52 »
Tranny fluid?  I think the top light is the alternator charging light is it blue?
« Reply #6 on: December 13, 2013, 21:52:20 »
.... What does the light mean? It's a 71 280sl.
Don't be afraid to consult the technical manual here!  ;)
http://www.sl113.org/wiki/Electrical/DashboardInstruments
Louiehenry
« Reply #7 on: December 13, 2013, 22:59:18 »
Haha! I actually did that right after I posted this, I thought I delete it, but I gues not!
I did discover the problem! Thanks again!
« Reply #8 on: December 14, 2013, 05:43:45 »
Hello Louie,
Check your brake fluid (may be your dash light problem).
For the shifting problem check the transmission fluid level. The transmission fluid is a little more difficult to check. Check it also.
Novamonte
« Reply #9 on: January 06, 2014, 20:33:57 »
Also check what fluid is in there now. I had a similar problem with second gear and when I checked the transmission it turned out that the PO had used regular transmission oil, not ATF which should be used even in the manual transmission in these cars. After changing the transmission oil the problem went away.
