Author Topic: Starting Restoration of my 250SL  (Read 7060 times)
promedical
« on: August 01, 2004, 16:40:59 »
Question.
I have the numbers in my book and I just find out my car doesn't have the original color. The second plate in the side has some number. I hope you all can help me to find out what is which one.
113-043- 12 0  335H  335H  5
6  00027  00777  426
I just could find out that the 335 is a blue color but no idea what's the H or the rest.
Two locksmith people came and they couldn't make the keys. I am still open to more suggestions.
Thanks to all
Gus
Gus
Re: Starting Restoration of my 250SL
« Reply #1 on: August 02, 2004, 17:16:38 »
To offer a little help, the H stands for the manufacturer of the paint, Herberts I think (the other you will see is G for Glasurit). The double 335 indicates that the top and body are the same color, which Meredith's book lists quite succinctly as "blue". The first string of numbers is the body (113), the 250SL (043), Left hand drive (1) and automatic (2). the last there digits, if this is from the plate on the left front inner fender are the body numbers which should match up with the number stamped on the upper edge, left, of the hood, the hard top, and the soft top cover. Do not confuse these with the VIN number, which is stamped on a plate located on the A pillar, for the 250. The VIN should also be stamped on the right front engine subframe under in the intake runner.
« Reply #2 on: August 02, 2004, 17:25:58 »
Gus,
Regarding keys for your car.  I used the local Mercedes dealer to obtain a key.  It was 7 or 8 years ago.  All they needed was the VIN to make the key.  I don't know if they made it on site or at a distribution center.
« Reply #3 on: August 03, 2004, 09:27:34 »
don't bother with locksmiths they are useless on these cars.  I have read posts where people have sought out expensive blanks and had expensive keys made all to simply avoid going to a dealer--and in the process they've spent a lot of time and more money then simply going to MB.
Keys are ordered by an MB Dealer and are not very expensive; I think around $12 each from Caliber.  You need the VIN number and they'll give you original keys--which are great unless something has been changed--say the gas cap replaced, or a door handle.
promedical
« Reply #4 on: August 04, 2004, 18:50:20 »
Hello all: Ok Key's problem was solve. Following your advices I got the codes from MB and keys are on their way. Great!. Now does anybody has the blue color (335) and can send me a picture to see how it looks like?
Gus
Gus
« Reply #5 on: August 06, 2004, 05:45:59 »
You can try www.paintscratch.com. They have a list of paint codes and a sample of the color. The computer is not the optimum way of seeing the colors, but it should give you an idea. Or you could order a small bottle of the color from them to see for yourself.
« Reply #6 on: August 07, 2004, 16:50:27 »
What level restoration are you planning to do?  Have you taken a look at Jans pics?  That car is really nice!  Keep us posted and we want to see your progress.  Good luck and have fun with it!
promedical
« Reply #7 on: August 26, 2004, 16:24:20 »
Hello Everybody:
Well, keys came from the dealer. They didn't work (Not ignition switch, nor glove compartment, nor gasoline cover, the only worked was the trunk key and doors).
I guess we might have to order a new ignition switch? or another suggestion? I am a little sad I tought I could start the baby, but not yet.
Gus
Gus
« Reply #8 on: August 26, 2004, 16:55:23 »
By the way, here's a link to a swtach of your color, 335H:
http://www.190slgroup.com/tech/colors/db335.JPG
graphic66
« Reply #9 on: August 26, 2004, 18:31:51 »
You have to search out a good old locksmith. My good friend is a master locksmith and can sit in the car with a blank, a magnifier, small vise grip pliers, and a small triangular file and after about an hour he has your key. He won't tell me how he does it but I think he just looks to see where, one by one the tumblers are marking the key by turning it hard with the vise grips then looking closely and filing. Seems to work for him. I also needed blanks and after just one day he had a baggie full of the exact ones I needed. All he said was he found them in Buffalo.
« Reply #10 on: August 26, 2004, 20:49:32 »
Gus,
Try getting the lock codes right off the lock.  The ignition switch might be pretty difficult, but the glove compartment and gas cap should be easy.  From these codes you should be able to get correct keys.  I don't know if you would get them from the dealer or a locksmith using these codes.
