Author Topic: Exhaust O Rings Part Number  (Read 3232 times)
250SLFranco
« on: June 19, 2013, 22:14:56 »
I know this has been discussed before, but I find I need to replace the larger rubber O Rings used in the middle of my exhaust system and I have not been able to find the part number for those particular O Rings.  If anyone has the part number I need and a good vendor, I as usual, would certainly appreciate the help.  Thanks in advance.
250SLFranco
Larry & Norma
Re: Exhaust O Rings Part Number
« Reply #1 on: June 20, 2013, 08:36:07 »
Any auto store will have a similar item much cheaper than Mercedes prices. I get mine from 'Halfords' here in the uk.
They work fine.
Larry Hall (Gnuface)
2023 Ioniq6
2005 C230
250SLFranco
« Reply #2 on: June 20, 2013, 16:50:22 »
I have the wrong size O rings on my exhaust system now, so that is why I need the part number or the correct size.  It has been identified that the center O Rings are larger that the rear O Rings.  Whoever worked on my exaust system (Midas Muffler) used the same size throughout.
