Author Topic: seats in 230sl : mounted mirrored?  (Read 6701 times)
Rodolfo
« on: June 10, 2013, 18:35:08 »
My dear pagoda friends,
The driver seat in my LHD car tended to be softer at the right side (door side). I thought it might have been the springs of the seat. I dismounted the. The seat springs looked quite good.
It seems that the left side of the driver’s seat is a bit stiffer because it is leaning on the middle console.
Now I think that maybe the seat cushions in the past are mounted wrong: I think that they mounted the seat of the right seat on the left seat and vice versa.
I am not sure of that. One side of the seat seems to be wider than the other: the seat cushion is not symmetric, I mean. Now the widest side is to the center of the car and so touching the middle console. I think maybe they should be mirrored: changing the cushions to the opposite seats, I mean.
I took two photos of the situation now.
Are they mounted wrong?
It is a 230 sl from 1966.
Thank you in advance.
Rudy
w113dude
Re: seats in 230sl : mounted mirrored?
« Reply #1 on: June 10, 2013, 20:44:26 »
Rudy,
I don't see anything unusual other than regular ware, the driver side gets a lot more use specially the door side backrest as you get in and out of the car you tend to lean towards that side more to get out, I have the same issue with my 300CD, changing the inner padding of the backrest will take care of it.
« Reply #2 on: June 10, 2013, 23:23:55 »
As an interim rather than a total rebuild, you could always do the noodle trick.  Do a search under 'seat noodles' and you will get the gist.  It makes the world of difference for tired seats
manz376
« Reply #3 on: June 11, 2013, 19:27:57 »
I think they are mounted incorrectly, the wider part of the seat base should be nearer the door.
Someone correct me if I'm wrong.
georgem
« Reply #4 on: June 11, 2013, 20:20:54 »
I agree with manz - swap them over - another test might be the seat slide lever - on mine it is inboard next to the transmission. I also seem to remember a discussion re this a year or so ago.
George McDonald
Brisbane
230 Sl
1973 VW Kombi Single Cab Ute
Alf
  • England, Surrey, Lightwater
« Reply #5 on: June 11, 2013, 21:21:07 »
Just checked my car and your are definitely the wrong way round
Alf
'69 280SL. Silver (180 G) with black hardtop
Rodolfo
« Reply #6 on: June 12, 2013, 20:45:12 »
I also think they are mounted reversed. Now my only concern is: all people who confirm drive RHD cars, I suppose (UK and Australia). Could someone a LHD confirm as well that the seat slide handles are inboard next to the tunnel?
If indeed the cushions are wrong placed, it will be some work: since the tilt levers are on the good side: door side. But the slide handle and cushion are apparently not.
« Reply #7 on: June 12, 2013, 22:18:04 »
Seats in LHD cars also should have the slide handle inboard next to the tunnel. Although I must admit I have put mine on the outside  :o
... since it is a lot easier to reach them up front and move the seat. I cannot get any points subtracted for that since I don't show my car.  ;D
Yes, you will have to open up the seats and place the tilt lever at the same side where the seat cushion is wider.
« Reply #8 on: June 13, 2013, 01:27:15 »
It may very well be they are in backwards -- but what I notice is how the seats seem to really be encroaching upon the center console. This could be the reversed-seat issue but is it possible the seats themselves are wrong (over-sized in some way?) If you reverse them, you may have clearance issue on pocket side.
I looked at mine and they too might be transposed? Although I am not 100 percent sure about this. The slider-guides are both inside as they should be -- and one of my covers has equal width on both sides of the cushion. At my measuring point its 5.5 inches. However, the other seat has a slightly wider cushion band 6 inches on one side, 5.25 on the other... Wide side on tunnel side but I have good clearance on both sides...
These are replacement seat covers from Miller's purchased about 10 years apart from each other.
Confused yet?
Sorry no pictures yet...
« Last Edit: June 13, 2013, 01:35:32 by J. Huber »
« Reply #9 on: June 13, 2013, 01:34:29 »
And...I just thought of something. I recall hearing that the early cars had a different seat shape than later ones (something we must specify when buying new covers.) Maybe yours being a 66 and mine a 63, the seats are patently different. Then it makes sense that your style with the curvy side need to be swapped around -- mine have a fairly straight edge on each side -- they may be wrong too but the transposition is not so dramatic...
So, having a nice conversation with myself here... thx J
Sure
J
Rodolfo
« Reply #10 on: June 15, 2013, 18:29:42 »
Today I excahanged the seats. They were indeed mounted mirrored . Was quickly done. Much beter now. I also included the "pool" thing.
Many thanks for the good advices
Rudy
