Author Topic: New Distributor for W113  (Read 11888 times)
Kemal
« on: March 31, 2013, 09:10:34 »
Happy Easter ...
A service shop is recommending this to replace the old, any thoughts and advice would be most helpful.
http://www.123ignition.nl/id/25.html
Thank you..
" I see this was discussed early 2008, any updates since? "
« Last Edit: March 31, 2013, 09:41:15 by 280SL71 »
Kemal
280SL
Manual LHD69
Larry & Norma
Re: New Distributor for W113
« Reply #1 on: March 31, 2013, 09:15:10 »
Hi Kemel,
I have one of these. It is a really worthwhile addition for a very smooth running engine and no points to adjust.
Don't forget to install a spring. Search this site for more info.
Larry
Larry Hall (Gnuface)
2023 Ioniq6
2005 C230
Kemal
« Reply #2 on: March 31, 2013, 14:53:17 »
Hi Kemel,
Larry
Thank you Larry,
Much appreciated .
Kemal
280SL
Manual LHD69
71Beige280SL
  • USA, OH, Madeira
  • 1971 280 SL
« Reply #3 on: March 31, 2013, 15:36:07 »
Kemal,
I second Larry's recommendation. I had one installed last summer. The car runs fantastic.
- 2024 Mercedes GLE 350
- 2024 AMG C43 Sedan
gerster
« Reply #4 on: March 31, 2013, 19:38:17 »
v.Dijk in Lisserbroek did install it in my car about a month ago and I must admitted that the car is running better and cold start is alot faster as in the past.
Gr. Ger.
« Reply #5 on: March 31, 2013, 20:26:34 »
Kemal, this is what I did.  Go for it!  If installed properly you won't regret it.
Kemal
« Reply #6 on: March 31, 2013, 21:43:22 »
Thank you all, I'll take care of it on Tuesday.
 I feel sick, too much chocolate today.  :-\
Kemal
280SL
Manual LHD69
« Reply #7 on: April 01, 2013, 00:34:11 »
Also check out Pagoda Notes, Volume 3 No 4. It has an in depth discussion of the 123 installation and use.
Harry
  • USA, TN, Knoxville
« Reply #8 on: April 01, 2013, 16:00:40 »
(Watching this thread.)  How do you get to Pagoda Notes, Volume 3, No 4 - or to Pagoda Notes for any sybject?
Harry Bailey
Knoxville, TN
1966 230SL
Automatic
« Reply #9 on: April 01, 2013, 16:59:26 »
Back issues are located in the restricted area for full paying members in the Technical Manual:
http://www.sl113.org/wiki/Restricted/PagodaNotes
Harry
« Reply #10 on: April 02, 2013, 09:02:52 »
Got it - thanks.
Harry Bailey
Knoxville, TN
1966 230SL
Automatic
w113dude
« Reply #11 on: April 02, 2013, 11:57:04 »
Which is the model 123 distributor that replaces the 051?
escapee
« Reply #12 on: September 04, 2013, 14:53:46 »
Thinking of buying this to replace my aging original distributor. Any modification needed or just a simple plug and play?
escapee
« Reply #13 on: September 04, 2013, 15:21:05 »
I found an old thread dicussing the 123 distributor, which generally answered all my questions.
http://www.sl113.org/forums/index.php?topic=8816.0.
Do let me know if you have any further information to share, either here or in the thread above. thanks
Palolo
« Reply #14 on: September 23, 2013, 03:46:47 »
In Kemal's link (above) it is the "Mercedes-6-R-V" which is one of the ones made by a company called "123ignition" from the Netherlands...
Not sure if you thought it was a distributor from a model of the W123 Mercedes cars, which is not the case.
If you are in the US, here is a link: http://www.123ignitionusa.com/mercedes.html
I have one in my W108 (gets rid of those pesky and useless ballast resistors) and another in my Fiat 500.
Bombus
« Reply #15 on: October 28, 2013, 13:46:47 »
I just replaced the BOSCH Distributor 0231.185009 of my 1968 280SL by the 123Ignition 123\MERC-6  with "curve selector" set to "8".  The engine is running smoothly and I can recommend the replacement.
« Reply #16 on: October 28, 2013, 19:38:45 »
Welcome Armin, and thanks for sharing your experience here!
