Author Topic: rust hole under kinder seat  (Read 5072 times)
bjudd
« on: March 15, 2013, 16:44:42 »
Just found a rust hole under kinder seat.  Was there a drain hole tube here?
Advice?
Thank you,
Brian
douglas dees
Re: rust hole under kinder seat
« Reply #1 on: March 15, 2013, 22:50:45 »
There is a drain in the lower rear  soft top seal on the passenger side that directs the water out tof the soft top compartment. It is the size of a pencil. I don't believe there is a drain the floor under the kinder seat.
Doug Dees
Bonnyboy
  • Canada, BC, North Vancouver
  • 1969 280sl Euro 4sp LSD
« Reply #2 on: March 15, 2013, 23:03:16 »
Its really hard to tell from the photo but it looks to me like there was a previous repair below the current rust hole next to where it meets the carpet .  My guess is that the rust came from below and just broke through the previous repair.
I don't have a kinder seat but had enough water to rust through the bottom of the metal below the parcel shelf on both sides.  In the picture I attached you can see that it was repaired previously so there appears to be a path for water to collect in that area.
Ian
69 280SL
73 CB750K
75 MGB
78 FLH
82 CB750SC
83 VF 1100C
94 FLHTCU
96 F-150
08 NPS50
12 Pro 4X
« Reply #3 on: March 16, 2013, 00:33:57 »
There's no drain hole there but I put one in when I restore a car.
It's a water trap and they always rust there.
I've recently seen an example where an owner spent €140,000 (yes, that one for regular readers) less than two years ago and it's already started to rust there..
nate
« Reply #4 on: March 16, 2013, 03:05:51 »
I'm no rust expert but it looks like the corrosion started on the undercarriage side and wormed it's way up.
bjudd
« Reply #5 on: April 03, 2013, 02:27:14 »
Thanks for the input.  I'll let you know what I find when I dig into the wound.    :)
