Author Topic: Rust Repair  (Read 6322 times)
Harry
  • USA, TN, Knoxville
Rust Repair
« on: March 11, 2013, 17:17:02 »
Does anyone have some pictures of the actual panels that make up the front floor board, the sills and the geometry inside/behind the sills?  I have some rust on mine and I'm just trying to decide how extensive it is and how best to repari it.  No amount of rust looks good but I think this is repairable.  I've seen the cut-a-ways but it's hard for me to visualize from those.  Actual photos of a car during the removal of various panels would be a big help.
Thanks!
Harry
Harry Bailey
Knoxville, TN
1966 230SL
Automatic
71Beige280SL
  • USA, OH, Madeira
  • 1971 280 SL
Re: Rust Repair
« Reply #1 on: March 11, 2013, 18:43:21 »
Do these help?
- 2024 Mercedes GLE 350
- 2024 AMG C43 Sedan
Harry
Re: Rust Repair
« Reply #2 on: March 11, 2013, 19:18:08 »
Yes they do.  The area in your 2nd photo where the lift seems to be going through a section you've cut-a-way is particularly interesting.  Do you have a photo looking towards the car (rather than pointing away from the car?
Thanks!
Harry
Harry Bailey
Knoxville, TN
1966 230SL
Automatic
Bonnyboy
  • Canada, BC, North Vancouver
  • 1969 280sl Euro 4sp LSD
Re: Rust Repair
« Reply #3 on: March 11, 2013, 20:57:10 »
I have to ask,  Mr. 71Beige280sl  what kind of welder are you using - wire, amperage, wire speed?   Those welds look awsome.
Ian
69 280SL
73 CB750K
75 MGB
78 FLH
82 CB750SC
83 VF 1100C
94 FLHTCU
96 F-150
08 NPS50
12 Pro 4X
Re: Rust Repair
« Reply #4 on: March 12, 2013, 12:47:30 »
Here is one of the inside sill structure. This was during dry fitting and before the firewall was replaced. Notice the inner section wraps from the top of the sill down and half way up the inner side. The floor just overlaps the sill at the sides. Check the area directly behind the sill on the inner rail as well.
I have a bunch of photos of the sill restoration so let me know if you need more.
71Beige280SL
  • USA, OH, Madeira
  • 1971 280 SL
Re: Rust Repair
« Reply #5 on: March 12, 2013, 13:01:19 »
Harry,
I think this is the one you're looking for. The arrow points to a structural repair inside the sill.
Bonnyboy,
I had the work done at Motoring Investments in San Diego. I am not sure of the wire, amperage or speed.
Khurram Darugar
Re: Rust Repair
« Reply #6 on: March 12, 2013, 13:32:38 »
The welds appear that way probably because they are stacked.  As opposed to one continuous mig weld a series a overlapping single welds are applied for the same result with more control and less grinding is required to remove excess material.
Its probably worth noting that most of these panels were originally spot welded.  So a continous butt weld may be overkill.  Although thats what i did ::)
Many restorers use weld through primer on the panel over lap and replicate spot welds using a spot weld hole punch on the panel edges and then weld into the hole (plus grind off excess).
And dont forget to grind off the zinc coating on galvanized repair panels edges prior to welding.
« Last Edit: March 12, 2013, 13:40:41 by Khurram Darugar »
Harry
Re: Rust Repair
« Reply #7 on: March 12, 2013, 16:50:47 »
Thanks very much 71Beige280SL and shvegel.  Actually, the cut-a-way through the sill showing the jack supports is the biggest help to me.  Looking at an exploded diagram on a Bud's Benz site, I see a Frame Rail, Frame Rail Cap and Rocker Panel Cover.  I gather your photo is end view of the Rail and Cap in position?  The photo is a big help.  It looks as though there is a paenl beneatht the lower trim piece that unscrews (and I have that feedback from the forum).  I am going to remove that piece soon and hopefully that will answer a bunch of my questions.  In the meantime, the additional photos that you offer would be much appreciated.
Thank you again,
Harry
Harry Bailey
Knoxville, TN
1966 230SL
Automatic
71Beige280SL
  • USA, OH, Madeira
  • 1971 280 SL
Re: Rust Repair
« Reply #8 on: March 12, 2013, 16:56:22 »
Harry - I have more pictures on my Mac at home. I am traveling this week but, happy to send a few more this weekend.
Harry
Re: Rust Repair
« Reply #9 on: March 13, 2013, 00:27:40 »
Please do - much appreciated.
Harry Bailey
Knoxville, TN
1966 230SL
Automatic
