Please check out joining the
Emergency Contact List
for help during your travels!
Fire wall insulation
Topic: Fire wall insulation (Read 3513 times)
Reischmann
January 31, 2013, 01:33:23 »
I am replacing the engine bay fire wall insulation.
Will regular contact cement work or should I be worried about it not holding up in the high heat?
Thank you,
Mike
Inactive
Platinum
USA, NY, New York
Re: Fire wall insulation
January 31, 2013, 11:06:54 »
Used 3M Super Trim Adhesive (08090) and all is OK after a season of driving.
The 3M can is marked "Heat and Moisture Resistant"
Richard M, NYC
Reischmann
Reply #2 on:
January 31, 2013, 12:19:33 »
Thank you for the quick reply.
M
Full Member
Platinum
USA, OH, Blacklick
Reply #3 on:
February 01, 2013, 05:35:35 »
Good advice to use the correct adhesive, as some spray adhesives will eventually release when used on plastics and synthetics. The plasticisors leach out of the plastic over time and attack the adhesive.
