Please check out joining the
Emergency Contact List
for help during your travels!
Should rear axle serial number correspond to engine number?
Topic: Should rear axle serial number correspond to engine number? (Read 4382 times)
rutger kohler
October 08, 2012, 04:28:24 »
Some time ago several members posted photos showing where the rear axle serial number is located. I have finally got around to cleaning my rear axle and have read the serial number and diff ratio. Should the serial number correspond with the engine number?
Full Member
Platinum
Australia, Victoria, Kyneton and Brisbane Queensland
Audit Committee
Re: Should rear axle serial number correspond to engine number?
October 08, 2012, 06:48:28 »
No, you will see if you have your data card that they also list the serial number of the axle.
1972 MB 280CE W114 Auto RHD 906G
rutger kohler
Reply #2 on:
October 08, 2012, 08:08:23 »
Hi Gary, thanks for that, i do have the data card but my German is not good enough to see what part represents the rear axle, can you help plse?
Full Member
Platinum
Audit Committee
Reply #3 on:
October 08, 2012, 09:03:44 »
Rutger,
There are a number of different Data Cards (DC) (4) depending which model you have and within some models, which year.
The link is to the data card area of the Technical Manual.
http://www.sl113.org/wiki/DataCard/DataCards
You can see from the cards that in Version 1 for early 230's it is item 7 on the DC
Version 2 which was for 250's I believe had the axle as item number 14, Version 3 also has the axle as item number 14 and Version 4 the rear axle as a seperate item serial number was removed.
You will need to compare your data card with the examples to establish which your card is as I am not sure what model you have.
Hope that helps.
rutger kohler
Reply #4 on:
October 08, 2012, 09:14:58 »
Hi Gary, thanks for that, my version is Version 4 and the data card has dropped the rear axle number off, never mind, thanks anyway.
