Author Topic: This is not good - this week of all weeks  (Read 26052 times)
« on: September 15, 2012, 14:39:29 »
Went for a little jaunt this morning - 20 miles
On the way back the engine was misfiring under load - from about 2500 rpm - and at idle. It revs but is clearly missing a cylinder occasionaly (don't you just love the occasionally" word?). If I take it up the rev range slowy, it seems smooth enough. Get a little heavy footed, and it starts to misfire. Take it out of gear, and rev it, all sounds fine....
Got home, pushed all my leads on to make a decent connection, then removed the HT leads from the plugs and refit. Car revs nicely and not missing a beat
Went to get fuel, and under load, the problem reappeared. I've had a similar issue before (but at higher revs) with a cracked rotor arm (dizzy was fine, just the arm). Running a Crane electronic igntion. I did 100+mile 2 weeks back and had no issue whatsoever.
I checked the oil while getting fuel and it was VERY low (below the notch in the dipstick)  - not been leaking so think i must have been burning it... so, oh collectively wise-ones... what have i got?
An electrical problem from the dizzy onwards- never had a Crane fail so no idea if it can do an intermittent fail (ie does it either work or stop completely?)
A spark problem (although it's clearly worse under load but I would guess I am running rich seeing as the car was serviced <1000miles ago and the garage floor is not awash in oil)
A worse problem (eg something mechanical/valve train etc) that may be lack of oil related - although it seems fine when not under load?
And can it be fixed before Wednesday night!!
Any sane thoughts, much appreciated.
Re: This is not good - this week of all weeks
« Reply #1 on: September 15, 2012, 14:45:00 »
Uhoh... you had better get that fixed soon...
Simple check: how do your spark plugs look?
When was the last time you checked the oil (i.e. is it a recent change in level)?
Is your exhaust fume looking different?
Are all your injectors seated correctly?
Is the gasket ok?
My advice... consult a real expert quick! Hope it get's better soon...
Larry & Norma
« Reply #2 on: September 15, 2012, 14:50:44 »
Wow that's a real bummer Tosh :-[ :-[
I will echo Peter, if it has been running rich then the plugs may be fouled.
Where has the oil gone? must be smoking surely?
Maybe Stick can help at short notice.
Larry Hall (Gnuface)
2023 Ioniq6
2005 C230
« Reply #3 on: September 15, 2012, 15:00:41 »
Thanks - sounds like a job for Colin. I'll pm him as I am waaaay out of my depth!
Neil Thompson
  • United Kingdom, England, Louth
« Reply #4 on: September 15, 2012, 19:33:29 »
Tosh, I had a misfire under light load recently and was advised by Stick to adjust the length of the fuel injection pump rod which worked, he's your man, make the call!, my day went from bad to worse too, last few jobs before the Euro event, fitted GB badge, cleaned car, fitted sat nav to screen, filled fuel - to the brim, then a big pool of fuel dripping off the exhaust. looks like we're both busy now, good luck
1964 230 SL RHD DB304 Horizon Blue
1957 190 SL RHD DB180 Silver
1988 R107 300 SL RHD DB199 Blue Black
1978 C123 230C 2dr Auto RHD Silver
Neil,
Check the small rubber connecting pipes under the tank filler shield in the bot (trunk)
Naj
Neil Thompson
« Reply #6 on: September 15, 2012, 20:42:02 »
Tosh, sorry for gatecrashing.
Naj, thanks, - see http://www.sl113.org/forums/index.php?topic=17170.0 for progress
Neil
« Reply #7 on: September 15, 2012, 20:46:12 »
Don't forget your hi-viz vest and your breathlyser test kist for France. HiViz in the car, not the boot
And if your sat nav has speed camera detection.....
« Reply #8 on: September 15, 2012, 20:58:06 »
Tosh - FWIW: check that the FI  linkages are all tight, including the brackets that support the linkages. And try a fresh set of spark plugs. I woild also check the resistance of the spark plug wires, maybe one has gone bad. Good luck, it's probably something small.
jeblack123
  • USA, GA, Albany
« Reply #9 on: September 16, 2012, 06:13:06 »
Tosh,
I had almost the exact same issue 2 weeks ago and my mechanic replaced  a fouled spark plug and it ran much better. I went ahead and replaced the rest of them and it runs beautifully. I'm sure that you have already thought of this and probably checked it but wanted to let you know that it may be something simply (keeping my fingers crossed).
« Reply #10 on: September 16, 2012, 07:56:40 »
Thanks James - and Cees
Started beautifully this morning and had no misfire - sounds sweet. But then it did yesterday until it got hot.
Stick pm'd me back and I'll take it to his place tomorrow (it's only 120 miles away!) and see what they can do!
« Reply #11 on: September 16, 2012, 08:30:31 »
Good. We wouldn't want to miss your car at the event...
« Reply #12 on: September 16, 2012, 13:32:08 »
I would install a fresh set of spark plugs before the trip. The oil consumption problem, may or may not be related. If your exhaust is not smoking, and you have no serious leaks, the problem may be worn exhaust valve guides or seals. Not an immediate problem, but keep your eye on the oil level.
If the spark plugs are getting oil fouled, the problem may be intake valve guides or seal, or (less likely) piston rings. Oil or fuel fouled spark plugs will cause your engine miss also.
If spark plugs do not solve the miss problem or only temporarily solve it, you may have a component on the ignition breaking down. An ignition coil failure can be very elusive. They do not fail all at once, but die a lingering death. Temperature, rpms, condition of other ignition components may all contribute.
Read your old set of spark plugs for clues. As per Cees also check the resistance of the spark plug and coil wires.
Good luck.
« Reply #13 on: September 16, 2012, 13:57:39 »
Thanks again
I am running VERY rich - at least I have splatters of black deposits coming out of my exhaust pipe. So LIKELY the plugs are fouled and causing the observable problem
Question now is why would it be that rich - either something is out of whack (hopefully) or I have oil going from somewhere I want it to somewhere I don't! Colin Ferns will have fun with that!
ejboyd5
  • Southold, NY
« Reply #14 on: September 16, 2012, 14:53:56 »
Replace the coil.
« Reply #15 on: September 17, 2012, 06:18:25 »
Made it 110 of the 120 miles trouble free. Which is good. I drove "lighter of foot" than normal. On the couple of occasions I tried a little harder  acceleration I had puffs of smoke flying out the back. We await to find out the reason!
« Reply #16 on: September 17, 2012, 12:18:07 »
OOoooooooKKKkkkkk!
My friend Janis working for Colin (stick) took a look at my car. My smoke is a matching accessory to the car, ie is bue/white/grey rather than black. So he ruled out running rich
The plugs are bunged up, black and gunky so I clearly have oil in the combustion chamber and that's the likeliest cause of any misfiring issue I have rather than in the ignition side of things
He thinks the issue is that the gap between piston/compression rings and cylnder wall has worn a bit too big and so oil is getting in that way. Thinks - too busy this week to get the head off and have a look
And of course, once the head is off, there's no guarantee that the block etc won't have to come out if major remedials are needed
So, I have come away with a spare set of plugs, will clean up the ones that are in there and book the car in for work next week.
Will it last the ~1,000 mile trip over the next dew days? Don't know but it seems to run better when going (just sat in traffic for 90 minutes and it sounds like a box of spanners right now) which is a good thing. Advice please folks?  Bring a sickly car and perhaps ask for help giving plugs a scrub or come in the Range Rover?? :o
« Reply #17 on: September 17, 2012, 12:36:54 »
Tough call. We prefer Pagoda's... :) but if it makes things worse... :'( And roadside assistance is one thing, but not if takes all weekend... >:( Decisions decisions...  :-\
« Reply #18 on: September 17, 2012, 13:52:13 »
Management has said "we are going in Audrey"
So it'll be a Poorly Pagoda Peregrination.
I anticipate a daily plug clean!
« Reply #19 on: September 17, 2012, 16:14:39 »
One thing though, once there you will have plenty of assistants ready to volunteer, whether you really want them or not!
« Reply #20 on: September 17, 2012, 16:31:45 »
Small mercies... sort of
Had all the plugs out and only one of them is gunked up and that is cylinder 6 (or is it 1) nearest the firewall - so when it comes to roadside and hotel carpark over a breakfast cappuccino repairs it should be pretty quick. Black/oily/gunky. But not wet so I guess that's a good thing
I now know exactly where the problem is and fixing one is SO much easier than fixing/cleaning all 6 (both from a plug perspective and from the view of getting it repaired). That said, once the head is off (and potentially the engine out if the rings have gone/need replacing...) why would I only "fix" the one? So it looks like another expensive autumn....
See you Friday. I'll bring the latex gloves!
Larry & Norma
« Reply #21 on: September 17, 2012, 16:42:42 »
............and some oil! Would be interesting to know what compression readings you have?
Looking forward to the meet on Friday see you then :)
2023 Ioniq6
2005 C230
Neil Thompson
« Reply #22 on: September 17, 2012, 18:58:29 »
I know it's not a fix but is there a spark plug that is more suitable to oily engines that could be used in no.6 cylinder?
Neil
jameshoward
« Reply #23 on: September 17, 2012, 19:17:11 »
James,
It may be worth getting a garage to do your compression readings. Quickest job ever and you don't need your specialist to do it. It'll give you an idea of whether his diagnosis is right or near right/miles off. Seems a bit dramatic to talk of pulling heads, perhaps. You could get a tester in halfords for v little and do it yourself. Dead easy. http://www.halfords.com/webapp/wcs/stores/servlet/product_storeId_10001_catalogId_10151_productId_199553_langId_-1_categoryId_255216
Also, how about just getting a new coil and perhaps changing the wires around (at both ends) cyl 5 for 6 and vice versa, and see if the problem stays with 6. Maybe bring a new coil, plugs and wires with you? If there is a garage, you could get them to check the valve clearance also. (Good tour on here by Alfred and another easy job if you have a bit of time).
Are you on points or elec ignition (I seem to recall you're elec, but can't quite remember)?
I think any decent old fashioned garage could take a good look at your car if you don't have time. I'd say it's worth a bit more investigation as it could be a relatively simple fix. Moreover, your arguments on the way from the kitchen fitters in Germany to Belgium could be all about the worktop granite and oak-effect doors, rather than the fact that you forgot to look up ADACs phone number before you left home.
In short, I see your '3 P's' and offer the Army's 7P's with a SL113.org 8th added for effect: Prior Preparation and Planning Prevents Piss Poor Pagoda Performance (struggles for relevance at this point...I'll get my coat).
James Howard
1966 LHD 230SL
« Reply #24 on: September 17, 2012, 19:42:56 »
Thanks Colonel
Shall pop back to Halfords and bring it/results with me - time permitting. If 6 is way low I'll be wiser....
