Author Topic: US to European headlights conversion....how about bezel?  (Read 8102 times)
Flyair
could anyone advise if changing headlights from US to European style also requires changing bezels or are they the same?
many thanks
Stan
Stan
2011 SL550 AMG
2011 GL
2015 GLA
jameshoward
Re: US to European headlights conversion....how about bezel?
« Reply #1 on: August 22, 2012, 16:40:18 »
Alas, they are different.
Perhaps not hugely, but there is a small plate thingy on the US ones that would need to be removed (if I've got that the right way around) anyway, point is that to go from US to Euro, you'd need to mod your US ones such that you couldn't easily change them back again. Whilst the bezels aren't cheap, you may feel that buying the ones designed for the Euro lights is worth doing. I made the change and got new bezels, plus the new chrome looks great.
JH
James Howard
1966 LHD 230SL
« Reply #2 on: August 22, 2012, 20:06:46 »
As James points out, there's a small notch that needs to be removed (dremel tool works fine). I did that and couldn,t be happier. Once the notch is removed, they fit perfectly.
jameshoward
« Reply #3 on: August 22, 2012, 21:28:51 »
Thanks, Cees, for clearing that up. I thought it was you who'd posted on this before but didn't want to stitch you up I case I got it wrong.
I can't remember the price of the rings exactly, but I think they were about £80 for the Euro set. Probably. But that would have been about 2 years ago.
James Howard
1966 LHD 230SL
Flyair
« Reply #4 on: August 23, 2012, 09:24:27 »
Many thanks to all for clarifying this. I have found Euro style bezels at SLS shop at 450 Euro for two, which means 600 $, well over the price quoted by James (unless he has his own hidden cheap sources :)).
At this price, I will seriously consider dremel tool as advised by Cees.
thaks once more
Stan
2011 SL550 AMG
2011 GL
2015 GLA
jameshoward
« Reply #5 on: August 23, 2012, 11:20:16 »
Ouch. Just checked the price, and you're right. That's expensive. They've gone up quite a bit, I think.
I'd be digging out the dremel at that point.
James Howard
1966 LHD 230SL
tel76
« Reply #6 on: August 25, 2012, 08:43:23 »
Are there any pictures of what has to be ground off?
Eric
Jordan
  • Canada, ON, Jordan
« Reply #7 on: August 25, 2012, 12:36:04 »
I would also be interested in seeing the picture if anyone can provide one.  I switched mine to Euro lights but did not do any grinding on the bezel.  They seem a bit loose.
Thanks.
Marcus
66 230SL  Euro 4 speed
Flyair
« Reply #8 on: August 29, 2012, 23:30:19 »
I will attempt the conversion with lights that arrived from SLS (they look REEEAAALLY great) using the US style bezels and will take pictures while doing this, so stay put, although it may not happen before a couple of weeks.
Stan
Stan
2011 SL550 AMG
2011 GL
2015 GLA
« Reply #9 on: August 30, 2012, 03:33:00 »
Stan,
Take lots of photos and at the end of the process it would write up an instruction as it would ba a good thing to put into the Tech Manual as there are plenty that have and will do it in future as well.
Flyair
« Reply #10 on: August 31, 2012, 22:29:00 »
Garry,
Will do. In fact I have already taken some. I think also to describe the process step by step, but if you put it into instruction frames, this would be great.
Stan
Stan
2011 SL550 AMG
2011 GL
2015 GLA
