Author Topic: Help with underdash stuff  (Read 3870 times)
jeblack123
  • USA, GA, Albany
« on: August 18, 2012, 20:50:33 »
At the risk of appearig ignorant to some and proving it to others, can someone tell me the purpose of the hole in the underdash panel on the driver's side (one on the passenger side as well) and the switch (button) next to it? I have a LHD 1968 280 SL Euro version automatic. Thanks again.
Re: Help with underdash stuff
« Reply #1 on: August 19, 2012, 06:29:03 »
The hole is there to let cold or hot air enter the foot wells on each side when the grey lever on the dash is turned to the right (down arrow):
The switch is not original. I can't help you here, you should trace the wires.
« Last Edit: August 19, 2012, 06:37:01 by 66andBlue »
ricrose
« Reply #2 on: August 19, 2012, 07:35:04 »
I wouldn't be suprised if a switch in that position is some kind of isolator / security switch or button. I can't see any other reason for putting one right out of sight and reach like that.
Richard
jeblack123
  • USA, GA, Albany
« Reply #3 on: August 19, 2012, 10:49:28 »
Thank you both for you responses. Should there be a hose of some sort be attached to the holes to direct the air to the footwells. The PO had A/C but removed it duriong his ownership, so I am unsure of what, if anything, should be there.
james
49er
  • USA, CA, El Dorado Hills
« Reply #4 on: August 19, 2012, 13:53:34 »
No hose, just the "vent" hole.
1969 280SL 003820
4 speed manual, PS. 77K+miles
