Author Topic: Electric radio antenna switch  (Read 5671 times)
« on: June 03, 2012, 15:46:51 »
Dear All,
As per the data card my car was ordered without a radio, but with an automatic/electric antenna.
Do you know if the antenna was operated through a radio (antenna out when the radio turned on) or should it have a separate switch somewhere on the dashboard? And if so - what kind of switch was it and where was it located?
Best regards,
Paweł
philmas
Re: Electric radio antenna switch
« Reply #1 on: June 03, 2012, 20:33:55 »
On a Becker radio, antenna should be operated directly from the set.There is a connector at the back for this purpose, and the antenna will rise up when you switch the radio on.
I don't know for the other brands (Blaupunkt...).
Hope this helps
« Last Edit: June 03, 2012, 20:43:44 by philmas »
Philippe from Paris
Euro '71 280SL manual 4sp
49er
  • USA, CA, El Dorado Hills
« Reply #2 on: June 03, 2012, 23:00:56 »
Same for the Blaupunkt. My original failed a after a few years and I replaced it with a manual antenna.
1969 280SL 003820
4 speed manual, PS. 77K+miles
« Reply #3 on: June 05, 2012, 19:27:35 »
Thank you gentlemen, it is a great help!
It suggests the antenna operation by the set itself - this is what I thought...
Thanks!
« Reply #4 on: June 14, 2012, 15:06:12 »
If the Becker radio has a remote amp, the antenna control connection is on the amp, otherwise it is on the back of the main radio.
« Reply #5 on: June 16, 2012, 11:13:46 »
Thanks again, got the picture!
