Author Topic: idle speed solinoid  (Read 4674 times)
davids
idle speed solinoid
« on: April 12, 2012, 21:58:31 »
trying to hook up idle speed solinoid on 1971 280sl non euro does any now of a color coded wiring diagram that i could get a copy of?
twistedtree
  • USA, VT
Re: idle speed solinoid
« Reply #1 on: April 12, 2012, 23:00:15 »
Check out the tech manual and the Premium Contents.  There's a really nice color wiring diagram.
1964 MB 230SL
1970 MB 280SL
2023 BMW x3
davids
« Reply #2 on: April 13, 2012, 15:17:54 »
there is not a color version for the 1971sl us version
ctaylor738
  • USA, VA, Falls Church
« Reply #3 on: April 13, 2012, 15:40:29 »
What are you trying to hook the solenoid up to?
It can be used to raise the idle when the auto trans goes into gear, or when the AC is turned on.
Chuck Taylor
1963 230SL #00133
1966 230SL #15274 (sold)
1970 280SL #14076 (sold)
Falls Church VA
davids
« Reply #4 on: April 13, 2012, 15:48:22 »
idle drops really low when we turn a/c on ,and there is no wiring going to idle speed control ,so trying to figure it out. i found one place that says it should be hooked up to valves on tranny and another post says it should go to venturie and kick down.dont know what to do.
ctaylor738
« Reply #5 on: April 13, 2012, 16:01:12 »
If you want the solenoid to operate when the AC is turned on, run a wire from 87 on the AC compressor relay (or the compressor) to one terminal for positive, and have a constant ground on the other.
Chuck Taylor
1963 230SL #00133
Falls Church VA
davids
« Reply #6 on: April 13, 2012, 16:07:50 »
Thank you that sounds simple will do .
